+2
jwb474
Seamus
6 posters
    SMT-334 Temperature Compensated for Better Image Stability
    Seamus
    Seamus
    SMT-334 Temperature Compensated for Better Image Stability Empty SMT-334 Temperature Compensated for Better Image Stability
    Post by Seamus Fri Oct 25, 2024 6:46 pm
    The LM334 as implemented in amps using it for phase splitter bias suffers from getting too hot and thermal drift.
    Temperature stability can be improved by mounting under the board and made near perfect by compensation.
    Miller Audio has introduced a DROP IN SMT version called the SMT-334 which solves phase splitter drift.
    SMT-334
    SMT-334 Temperature Compensated for Better Image Stability Smt-3310
    I have ZERO affiliation with Miller Audio. I found the link here.
    Last edited by Seamus on Fri Oct 25, 2024 6:47 pm; edited 1 time in total (Reason for editing : calification)
    jwb474
    SMT-334 Temperature Compensated for Better Image Stability Empty Re: SMT-334 Temperature Compensated for Better Image Stability
    Post by jwb474 Sat Oct 26, 2024 2:15 am
    I was too looking into this issue.  I came across this site: https://www.audioamp.eu/the-problem-boards-vta-st-70-with-lm334-is-solved-ccs-zero-temperature-coefficient-current-source-for-tube-phase-inverter-en/?nastav_menu=USD.
    Back in Jan 17-2024 I copied the page and the cost was just over $5.00, now it's $9.74. Talk about inflation! SMT-334 Temperature Compensated for Better Image Stability Affraid
    Also at that time they were out of stock, so I decided to do a PWB using thru-hole parts that I had on hand.
    SMT-334 Temperature Compensated for Better Image Stability Lu9Z0P  SMT-334 Temperature Compensated for Better Image Stability HeuUXN  SMT-334 Temperature Compensated for Better Image Stability TGF4VH
    I decided to use LTSpice and model the performance of the 334 with and without compensation. Here are the results:
    Without compensation:
    SMT-334 Temperature Compensated for Better Image Stability TR03yv
    As seen from the results the change in ma from 10C to 100C is about 7.1ma to 9.4ma, a delta of 2.3ma. The 9.4 ma puts it close to the spec limit of the 334. With tolerances figured in it is possible
    to exceed the limits of the 334 and may cause a problem, although in actual practice there has been little issues.
    With compensation:
    SMT-334 Temperature Compensated for Better Image Stability SMH4go
    As seen from the results the change in ma from 10C to 100C is about 7.4ma to 7.7ma, a delta of 0.3ma. The 334 now stays well within it's rating.
    Seamus
    Seamus
    Post by Seamus Sat Oct 26, 2024 10:35 am
    Notice any listening improvement?
    What amp do you have?
    jwb474
    Post by jwb474 Sun Oct 27, 2024 3:57 am
    Seamus wrote:Notice any listening improvement?
    Quite frankly, I have not noticed any difference in sound, I am not blessed with hearing acuity or "Golden Ears" as they say to pick up on any differences.
    This being a hobby of mine, I tend to fix things that are not really broken Smile SMT-334 Temperature Compensated for Better Image Stability Icon_smile
    I have the MK3 amps
    Last edited by jwb474 on Tue Oct 29, 2024 2:28 am; edited 1 time in total (Reason for editing : Change)
    Seamus
    Seamus
    Post by Seamus Sun Oct 27, 2024 9:26 am
    jwb474 wrote:This being a hobby of mine, I tend to fix things that are not really broken Smile SMT-334 Temperature Compensated for Better Image Stability Icon_smile
    HaHaHa!!!
    jwb474 wrote:I have the MK3 amps
    Location and current could play in audibility. According to page I referenced, the case temperature fluctuated considerably
    Where is the LM334 situated on the driver PCB and original current?
    billinrio
    billinrio
    Post by billinrio Mon Nov 04, 2024 10:07 am
    " in Jan 17-2024 I copied the page and the cost was just over $5.00, now it's $9.74. Talk about inflation! "
    That's not inflation; it's increased demand.
    Rec
    Post by Rec Wed Nov 06, 2024 8:41 pm
    I did this modification in the following way. Mounted LM334 on bottom of VTA driver board (M125). I bonded the diode with silicon glue to the. LM334 and used a few precision resistors, using VTA driver board.
    sonically, I like my amps much more since I did this change, although it would be difficult to pin it on this change, as I added a bunch of stuff. IMHO worth doing to improve stability of the phase splitter on VTA board. IMHO, using a component like lm334, which is known to have temp instability, it seems a no brainer. I doubt the OG driver boards use any sand....
    jwb474
    Post by jwb474 Thu Nov 07, 2024 8:10 am
    Rec wrote:I did this modification in the following way. Mounted LM334 on bottom of VTA driver board (M125). I bonded the diode with silicon glue to the. LM334 and used a few precision resistors, using VTA driver board.
    That's the best way to get the best compensation. My layout, referenced above, would allow me to stand the body of the diode up next to the LM334 and use thermal epoxy to secure the diode body to the LM334 body.
    Maybe someday when I don't have as many irons in the fire and I get industrious I will do that and figure out a easy way to measure current vs temp in actual application
    knotscott likes this post
    Seamus
    Seamus
    Post by Seamus Thu Nov 07, 2024 11:15 am
    jwb474 wrote:... figure out a easy way to measure current vs temp in actual application
    Measure the no signal voltage drop across the two plate resistors after the amp temperature has stabilized.
    jwb474 likes this post
    maltboy1
    Post by maltboy1 Fri Nov 08, 2024 11:30 pm
    Here's what I did FWIW. The resistors fit nicely on the top side, and the diode was mounted on the bottom side.
    SMT-334 Temperature Compensated for Better Image Stability St-7_p10
    jwb474
    Post by jwb474 Sat Nov 09, 2024 4:52 am
    maltboy1 wrote:Here's what I did FWIW. The resistors fit nicely on the top side, and the diode was mounted on the bottom side.
    That's a great looking mod.
    Seamus
    Seamus
    Post by Seamus Sat Nov 09, 2024 11:53 am
    The diode should be in as close thermal contact as possible to the 334 so the change in the diode vF with temperature compensates for the same property in the 334. Ideally with a thermal compound so as to make the two components one.
    jwb474 wrote:That's a great looking mod.
    A huge problem in HiFi today is looks over good engineering.
    The M-125s are anything but elegant but when properly built, OUTSTANDING!
    Last edited by Seamus on Sat Nov 09, 2024 11:54 am; edited 1 time in total (Reason for editing : more detail)
    jwb474
    Post by jwb474 Tue Nov 12, 2024 3:46 am
    Seamus wrote: The diode should be in as close thermal contact as possible to the 334 so the change in the diode vF with temperature compensates for the same property in the 334. Ideally with a thermal compound so as to make the two components one.
    That would be best. Looks like it would be easy enough to stand up the diode and lead form it so it would contact the 334.
    This is the thermal epoxy I use: https://www.digikey.com/en/products/detail/mg-chemicals/9460TC-3ML/13997491?utm_adgroup=&utm_source=google&utm_medium=cpc&utm_campaign=PMax%20Shopping_Product_Medium%20ROAS%20Categories&utm_term=&utm_content=&utm_id=go_cmp-20223376311_adg-_ad-__dev-c_ext-_prd-13997491_sig-Cj0KCQiA88a5BhDPARIsAFj595gqN7piVoLAF-gTipAjsgbggzECvnf3pXR-MIKSL8HphDqfK9-g5xwaAs5cEALw_wcB&gad_source=1&gclid=Cj0KCQiA88a5BhDPARIsAFj595gqN7piVoLAF-gTipAjsgbggzECvnf3pXR-MIKSL8HphDqfK9-g5xwaAs5cEALw_wcB
    Here's a link to MG Chemicals info page on thermal adhesive page: https://mgchemicals.com/category/adhesives/thermally-conductive-adhesives/
    jwb474
    Post by jwb474 Tue Nov 12, 2024 3:56 am
    jwb474 wrote: A huge problem in HiFi today is looks over good engineering.
    This is so true. Back in my engineering career days (A long time ago) the wishes of the marketing department often trumped the engineering department as long as the unit under design met their specs.
    Post by arledgsc Today at 3:26 pm
    Received LM-334 boards from Pavel and installed them this morning in the ST-120.  Had to mount them top side as the large stepped attenuator used restricts bottom side mounting. The amp still takes an hour or so to warm up to sound best but do believe I have slightly firmer bottom.  Anyway should have better stability over a wide temperature range versus stock.
      Current date/time is Sat Nov 23, 2024 10:18 pm
