    Grid and Plate wire routing
    heyraz
    heyraz
    Grid and Plate wire routing Empty Grid and Plate wire routing
    Post by heyraz Tue Jan 10, 2012 2:36 pm
    The stock ST-70 has a grid and plate wire twisted together between each valve and its output transformer (Blue and Green then Blue/White and Green/White). What is the rationale for this? Don't they carry different voltages and if so wouldn't any cancellation of hum would be unequal? Wouldn't the wire with the higher voltage induce a current into the lower voltage wire?
    I am building an amp from scratch with the pentode/triode switches and think it would be better to twist the grid wires (Green and Green/White) together and the same for the plate wires (Blue and Blue/White). After the twisted pairs are routed to a point between the valves they can be separated and connected accordingly. Am I wrong?
    Grid and Plate wire routing Empty Re: Grid and Plate wire routing
    Post by Bob Latino Tue Jan 10, 2012 3:12 pm
    Twisting these wires is not really necessary from a hum/noise point of view because these wires carry DC voltages not AC voltages. Twisting the wires does make for a neater appearance though on any ST-70 with no triode/ultralinear switches. Wires that carry AC voltages like the tube heaters should be twisted to cancel out any hum.
    Do they carry different voltages? Not really. The green and green/white wires (ultralinear screen taps or grids) may be 1 or 2 volts higher in voltage than the plates. (blue and blue/white wires). The voltage gradient is so low that virtually no voltage will be induced. You can just use single runs (untwisted) of wire to connect up your triode/ultralinear switches.
    heyraz
    heyraz
    Post by heyraz Tue Jan 10, 2012 7:23 pm
    Thanks for clearing that up. Rich
      Current date/time is Fri Apr 26, 2024 7:05 am
