    My Dynaco ST70 1st anniversary
    evgenibgr
    My Dynaco ST70 1st anniversary Empty My Dynaco ST70 1st anniversary
    Post by evgenibgr Mon Mar 18, 2013 6:19 am
    Hello Dynaco fans.
    I bought my Dynaco ST70 from Bob assembled with all upgrades. The sound was very good. I tried different tubes during this time. I found that the sound best for me with Mulard CV4024 and 6P3S-E Russian tubes. Then I decided to upgrade all parts. Because, as it turns out each element have affects the sound quality.
    I began by coupling capacitors Mundorf Silver/Gold in Oil and most resistors Caddock MK132 and Amtrans AMRG. The result is impressive. Full sound, from low to high. That stimulates me to move on. I did a lot of orders from Partsconnection. I changed all the other resistors and capacitors. I used 220uf MUNDORF M-Lytic HV + additional capacitors in the power supply after the choke. On VTA board i put Nichicon KX 100and150uF 450V and ELNA Silmic II 100uF/100V very good improvement. Very important for sound are resistors R44 and R39(not only) - AMRG in this position are fine.
    I changed the internal wiring with Kimber TCSS hook-up wire (very transparent sound).
    I many wondering what resistors to put on R11, R13, R19 and R21. I chose Kiwame, but I'm not sure this is the best choice.
    For amplification I use shunt attenuator scheme with 15k TX2575 shunt resistor and 50k stepped Attenuator.
    I changed input RCA with Vampire CM1F/CB and binding post with CMC 858-S-CU-G Pure Copper Gold platted.  I replace and fuse holder with ACME cryo silver platted. I put Oyaide R-inlet for possibility to try different power cords.
    Now sound is rich, fuller and sweet. I am satisfied.
    Hire is pictures from my baby.
    My Dynaco ST70 1st anniversary 20130317_122832_zpsd8d6cc43
    My Dynaco ST70 1st anniversary 20130317_1157411_zps758aaf9c
    My Dynaco ST70 1st anniversary 20130317_115810_zpsacea3ca6
    My Dynaco ST70 1st anniversary 20130317_122039_zps646e0166
    My Dynaco ST70 1st anniversary 20130317_122202_zps72c3717b
    My Dynaco ST70 1st anniversary 20130317_121824_zps61f18982
    PS: sorry for my english
    My Dynaco ST70 1st anniversary Empty Re: My Dynaco ST70 1st anniversary
    Post by peterh Mon Mar 18, 2013 7:53 am
    you replaced caps and resistors but kept the tubes ??
    evgenibgr
    Post by evgenibgr Mon Mar 18, 2013 7:59 am
    peterh wrote:you replaced caps and resistors but kept the tubes ??
    Yes with these tubes sound is best. I tried Telefunken 12AU7, ECC801S, Amperex Bugle Boy, Mullard E180CC and Gold Lion KT66.
      Current date/time is Fri Apr 26, 2024 8:34 pm
