    ST-35 upgrade
    Timmyjoe
    ST-35 upgrade Empty ST-35 upgrade
    Post by Timmyjoe Tue Feb 10, 2015 1:41 pm
    I have a ST-35 and plan on replacing and upgrading the PC 13 boards. Does anyone have any recommendations on a cap upgrade for C3, C4 and C5 ? Also, any recommendations on the 9 pin sockets ? Tnx TJ
    ST-35 upgrade Empty Re: ST-35 upgrade
    Post by GP49 Tue Feb 10, 2015 3:52 pm
    Timmy, you will get more response if this is posted in the BASKET section of the forum, not the PHOTO section.
    The BASKET section is where most of the discussion takes place.
    DynakitParts
    DynakitParts
    Post by DynakitParts Thu Feb 12, 2015 11:53 am
    Timmy...
    As far a these capacitors...take a look at Sonic Caps series Gen I. I have used these with the ST-35
    with good results plus they fit nicely on the PC-13 boards. As far as tube sockets..I would recommend the
    Micalex 9 pin sockets. I stock these in both the chassis & pc mount types. If your planning to replace the
    circuit boards...take a look at our Dynakit replacement PC-13 boards.
    Whatever you decide, avoid buying cheap boards on Ebay that are made in China.
    Kevin @ Dynakit
      Current date/time is Fri Apr 26, 2024 7:13 am
