    7199 to 6GH8A adapter
    Varlagger
    Post by Varlagger on Sun Jan 10, 2010 7:51 pm
    Hello,My first post.Haven't dug into forum too far, my subject may have been already covered.I've only owned my st-70 about a month.Inever researched 7199 tube availability before purchasing my amp.I understand this adaptation is good sounding ,at least until I decide to possibly change out the PC-3 board.Has any one used the adapter and does it sound OK? Thanks,Varlagger
    Re: 7199 to 6GH8A adapter
    Post by Bob Latino on Mon Jan 11, 2010 4:27 am
    Varlagger wrote:Hello,My first post.Haven't dug into forum too far, my subject may have been already covered.I've only owned my st-70 about a month.Inever researched 7199 tube availability before purchasing my amp.I understand this adaptation is good sounding ,at least until I decide to possibly change out the PC-3 board.Has any one used the adapter and does it sound OK? Thanks,Varlagger
    The 6GH8A tube is a tube that is very similar to the 7199 tube but it has different pin outs. You can use the 6GH8A tube as a replacement for a 7199 if you ...
    A. Rewire the pin socket
    OR
    B. Use a 6GH8A to 7199 adapter
    You can get an adapter from Dynakitparts to allow you to run a 6GH8A in place of the 7199. You just plug your adapter into the 7199 tube socket and then your 6GH8A tube into the adapter.
      Current date/time is Wed May 16, 2012 7:35 pm
