    SP14 and PH16 Preamps Voltage Gain in dB ?
    mijohn
    SP14 and PH16 Preamps Voltage Gain in dB ? Empty SP14 and PH16 Preamps Voltage Gain in dB ?
    Post by mijohn Sun Jun 14, 2015 2:33 am
    Does anyone know what voltage gain in dB I should get from the VTA SP14 and PH16 preamps in their standard kit configurations?
    (without the addition of SUT's in the PH16 case)
    Buying a new cartridge so the info would be helpful.
    Thanks.
    SP14 and PH16 Preamps Voltage Gain in dB ? Empty Re: SP14 and PH16 Preamps Voltage Gain in dB ?
    Post by arledgsc Sun Jun 14, 2015 3:36 pm
    Voltage gain of the ST-70 per ch. into an 8 ohm load is about 29dB. 31.2dB for the ST-120. This is considering 0.6V input sensitivity yields max. power output and output voltage measured at the speakers.
    mijohn
    Post by mijohn Mon Jun 15, 2015 12:21 am
    Thanks Arledgsc, but i'm looking for the voltage gain of the VTA SP14 and PH16 preamps. I've noted your Dynaco specs for future reference though.
    Post by Roy Mottram Tue Jun 16, 2015 7:00 pm
    SP14 gain is 10db, PH16 gain is 55db
    mijohn
    Post by mijohn Tue Jun 16, 2015 11:07 pm
    Thanks Roy!
      Current date/time is Fri Apr 26, 2024 7:29 pm
