    Reforming PAS quad caps
    tubenutr
    tubenutr
    Reforming PAS quad caps Empty Reforming PAS quad caps
    Post by tubenutr Mon Feb 29, 2016 5:26 pm
    Hey,
    I have another PAS2 just sitting around collecting dust. I would like to keep it stock as possible, so I'm wondering what is the procedure to reform the caps, especially the quad cap.
    Any help would be greatly appreciated.
    Mike
    Reforming PAS quad caps Empty Re: Reforming PAS quad caps
    Post by peterh Mon Feb 29, 2016 5:34 pm
    Eskimo wrote:Hey,
    Mike
    Just add B+ BUT limit current and take your time. PAS has no fuse so you might
    destroy the transformer if you just plug it in.
    Install a 10k resistor in series with the 12x4, before the first cap. Turn on and
    measure voltage buildup. if it get warm stop and retry next day.
    But, reforming is not the only problem, it might also loose capacitance.
    You also have 2 large caps in the filament circuit and a se rectifier. They might also age without
    graze.
    Replacing all of the above with :
    http://www.tubular-well.se/index.php/webshop/reservdelar/tubes4pro-psu-detail
    or simular board will fix all the above concerns.
    Post by Roy Mottram Tue Mar 01, 2016 9:24 pm
    replace the quad cap and the filament caps with this board, top of page
    http://www.tubenirvana.net/pas3-power-supplies.html
    tubenutr
    tubenutr
    Reforming PAS quad caps Empty Reforming PAS capacitors
    Post by tubenutr Fri Mar 04, 2016 9:46 pm
    T4H,
    That may be an option, but I wanted to keep this set of Dynas as stock as possible.
    You know, the nostalgia thing.
    Mike
    Post by Roy Mottram Sat Mar 05, 2016 12:12 am
    at a bare minimum, replace the 50 year old quad cap with this . . .
    http://www.dynakitparts.com/dynakit-products/capacitors/MULTI-SEC-ELECTROLYTIC-CAPAC
    and replace the selenium rectifier with a 1N4004 or better, along with a pair of new electrolytics 2200 or 3300uF rated 35vdc
    Post by deepee99 Tue Mar 22, 2016 11:17 am
    Eskimo,
    Envision that quad-cap as your avatar. It ages over time and even a blow-torch or a shot of dry ice won't straighten it back up. Very Happy
    daveshel
    daveshel
    Post by daveshel Tue Mar 22, 2016 10:01 pm
    So what's the advantage of using an expensive quad can cap over 4 cheaper electrolytics (other than the obvious ease of mounting/installation)?
    tubenutr
    tubenutr
    Post by tubenutr Tue Mar 22, 2016 10:27 pm
    Not much dave except the mounting.
    Here is an alternative to the expensive can cap:
    http://www.dynakitparts.com/dynakit-products/capacitors/MULTI-SECTION-ELECT-CAPACI
    Or you could buy tube nirvana's power supply #8 and eliminate a lot of junk.
      Current date/time is Fri Apr 26, 2024 1:53 pm
