I have never found a really effective way to clean old Dynaco PCBs. I am not sure what the waxy, gooey stuff that the boards are covered with is--but I know I'd like to get it off. Anyone have a favorite recipe to share?
Dirty, waxy, gummy Dynaco PCBs
j beede- Posts : 432
- Post n°1
Guest- Guest
Re: Dirty, waxy, gummy Dynaco PCBs
j beede wrote:I have never found a really effective way to clean old Dynaco PCBs. I am not sure what the waxy, gooey stuff that the boards are covered with is--but I know I'd like to get it off. Anyone have a favorite recipe to share?
easy! buy our clone PC5 and PC6 PAS upgrade kits!
PeterCapo- Posts : 491
The bottom side, a.k.a. "foil" side, of the original, brown Dynaco PCBs were purposely coated with wax. It's likely beeswax or some blend of waxes that protects the phenolic substrate from moisture.
Don’t remove it!
If you were to "clean" the wax off, the phenolic substrate would destabilize in some way (I found out the hard way a long time ago). The board will no longer be protected from moisture, which could cause it to warp and otherwise physically degrade over time. I cleaned mine with a lot of 91% isopropyl, and the boards warped and became very brittle - barely usable.
I discussed this issue with some chemical companies that make solvents and conformal coatings for PCBs, as I considered trying to find a better way to dissolve or even melt the wax off and then reapply some kind of fresh conformal coating to continue protecting the phenolic substrate. Unfortunately, one place recommended against using certain modern conformal coatings with phenolics, and even present-day coatings don’t necessarily protect from moisture as well as wax does. Another place I spoke with was concerned that any chemical used to remove the wax could take up residence in the substrate and physically destabilize it.
Who knows what else could happen over time. Anything that could dissolve the waxy gunk might also contribute to the pads and etches delaminating, which are not well-bonded to the substrate in the first place. Might also reduce the electrical resistance of the substrate between etches.
The phenolic material is just not very robust. But, this should certainly not be taken as evidence that the original Dynacos were cheaply made. The PCB technology just wasn’t up to where it is today. By the 1970s, Dynaco had begun using the newer green epoxy PCBs.
If you want to keep them, my suggestion would be to do as little as possible to original, brown Dynaco PCB substrate. The dust and built-up grime on the top side can be wiped or brushed off, but on the bottom side leave the wax alone. They'll remain gunky-looking underneath, but they can still work perfectly fine even if new parts are installed. If the pads or etches delaminate from desoldering/soldering heat, you can just run the part’s lead a little further along the etch to make the needed connection.
