    PAS 2/3/3X input selector wiring
    PAS 2/3/3X input selector wiring Empty PAS 2/3/3X input selector wiring
    Post by j beede Mon Jun 20, 2016 11:04 am
    Re-wiring the input selector on a PAS 2/3/X is a somewhat "fiddly" job. I see lots of PAS input selectors wired without twisting pairs or using shielded wire or coax. I wonder why that is.
    I am about to replace the RCA I/O board and would be interested in hearing about your experiences with twisted pairs versus individually shielded wire before I dive in.
    PAS 2/3/3X input selector wiring Empty Re: PAS 2/3/3X input selector wiring
    Post by Guest Mon Jun 20, 2016 4:15 pm
    j beede wrote:Re-wiring the input selector on a PAS 2/3/X is a somewhat "fiddly" job. I see lots of PAS input selectors wired without twisting pairs or using shielded wire or coax. I wonder why that is.
    we use and sell 24gauge pre twisted pair hookup wires. Easy to use and works very good.
    You ground the RCA socket end, the selector switch end, you curl back the ground wire, usually the white wire, see photo
    PAS 2/3/3X input selector wiring Selecotrwiring_zpsjglulypr
    PAS 2/3/3X input selector wiring Hughes8%201_zpsttpwhcar
      Current date/time is Fri Apr 26, 2024 10:39 pm
