I have read that when you increase the power supply filter capacitor value or run a solid state rectifier that you need a standby mode to allow the tubes to warm up before applying high voltage to prevent the cathodes of the power output tubes from cathode stripping.
Also that tube rectification has better bass but concerned that the rectifier tube is running at very close to maximum output and concerned about tube life.
