Just to get a better picture, are you feeding both the main speakers and sub from the M125's?
+5
arley
bluemeanies
LeGrace
9 posters
Biamp, yea or nay?
Tube Nube- Posts : 707
- Post n°26
Re: Biamp, yea or nay?
LeGrace- Posts : 388
- Post n°27
Tube Nube wrote:Just to get a better picture, are you feeding both the main speakers and sub from the M125's?
Previously I had a splitter on the Marantz pre outs. One side went to the M125's, the other to the sub. In this case the M125's see the full frequency spectrum. Now the splitters are eliminated, and the Marantz's pre outs connect directly into the the sub. The sub output jacks (it has L/R in and out jacks) then feed to the M125's. Meaning the M125's no longer see the lower frequencies below what I have set on the sub. Hopefully that answers your question. Surprised a what a difference it makes.
Biamping in another form, in that the low freq are all SS now, the rest tube powered...
- Post n°28
Hi LeGrace,
Got it. I actually started to write what I said, then " or is it like . . . ." Describing what you've just said, but was worried I would confuse the picture if your sub didnt work this way.
My subs work the same way, and it was really easy to set it up and play with the hi pass cutting frequency. I did find it muted the fidelity, which might have been the result of the high pass being poor quality, or the flimsy cables I used being an issue.
If you ever get the itch to try it, once you've decided on a high pass frequency you like, you can construct a 1st order (6 db per octave roll off) high pass filter consisting of a single (bipolar) cap per channel. There are formulas on the net, but the value of the cap is a function of the cutting frequency and the input impedance of your M125's. That would let you skip the subs internal high pass.
But there may be no need for it. Sounds like you've landed on a solution that works great for you.
Now you've inspired me to go and rescusitate my sub-woopers that have been sitting idle since I rearranged my listening room a few months ago.
- Post n°29
My speakers are on the low eff side (88db). Combine this with my preference for triode mode, I was asking a lot of the M125's. Now freed of the power sapping low end (burden shifted to the 500w sub), layer in in two brand new pairs of matched Genalex KT88 quads, man things are sounding sweet!
