I get a bit more hum/noise after the amps have been on for a couple of hours
and the power transformer has reached it's maximum temperature. Now I'm
speculating about separate transformers for filament as a way to reduce the
consumption from the main power transformer. I have found a 50va toroid
that's 80x35mm and I belive that I would be able to fit two of these in each
M-125 amp. They do not have any centertap but I found this description for
a workaround. Any comments ?
http://www.augustica.com/Tutorials/Tubes/mains_filament_wiring.htm
