    Tube Question
    bluemeanies
    bluemeanies
    Tube Question  Empty Tube Question
    Post by bluemeanies Tue Apr 11, 2017 10:10 am
    I been reading people mentioning the KT 150.
    IMO I think the KT120 is substantial in the m125 but I do not know much about the 150's.
    Is anyone here using the 150's in the m125's.
    Also what bias level are you using? I know the 88's and 120's have a .500 setting for two tubes but is it different for the 150's since they run hotter.
    Tube Question  Empty Re: Tube Question
    Post by Peter W. Tue Apr 11, 2017 10:44 am
    https://www.newsensor.com/pdf/tungsol/kt150-tungsol.pdf
    http://www.tungsol.com/specs/kt120-tung-sol-specs-curves.pdf
    Looks like distinctions without differences.
    Writing for myself, I would think/hope that New Sensor would spend its time making a better, more reliable 120 than create a 'new' tube of not-much distinction.
    Post by corndog71 Tue Apr 11, 2017 11:35 am
    There are a handful of amps out there being sold as KT150 amps but really they're just KT88 amps with KT150 tubes. Doing just a quick search I found one company that seems to make a true KT150 amp. 100W/ch monoblocks for only $50K/pr.
    Clearly designing and building transformers for the KT150 is a daunting and probably expensive endeavor. Very few seem to want to risk producing an amplifier for an expensive tube made by only one company.
    If I knew how to roll my own transformers I would like to build a proper KT150 amp.
    Post by Bob Latino Tue Apr 11, 2017 11:38 am
    bluemeanies wrote:I been reading people mentioning the KT 150.
    You can use the Tung-Sol KT150 output tube in the VTA M-125's. That said, they are much more expensive than the Tung-Sol KT120 and don't offer anything "more" than the KT120 in the M-125's .. Even when you use the KT120's in the M-125's, the KT120's are being used "as a KT88 or 6550 output tube" in the M-125's.
    Post by deepee99 Tue Apr 11, 2017 3:36 pm
    I'm still waiting to hear from anybody who has bought a quad of those EAT KT-88s at $1600.
      Current date/time is Fri Apr 26, 2024 8:28 am
