    Tube glow question
    Tube glow question Empty Tube glow question
    Post by Guest Fri Sep 07, 2018 12:58 pm
    I have four (fairly) new matched Kt88s courtesy of Jim McShane. They have about 40 hours of use on them and sound great and bias fine.
    However from the first day one of the tubes has glowed noticeably brighter compared to the others. Specifically on the bottom of the tube (not the top where all seem to glow about the same).
    I've moved the tubes around and re-biased--it is definitely the tube that glows brighter.
    Does this kind of small anomaly matter if everything else seems in order?
    Jay
    Tube glow question Empty Re: Tube glow question
    Post by j beede Fri Sep 07, 2018 1:12 pm
    I've not heard of anyone that included filament alignment or brightness as part of the matching process. The effect you are describing is usually due to the physical alignment and visibility of the filament--not that it is actually glowing brighter. If you see a difference in plate color or the blue/indigo/violet plasma while the tube is operating, that might be a different situation.
    Jim McShane
    Post by Jim McShane Fri Sep 07, 2018 1:51 pm
    jsl1234 wrote:Hi,
    Jay
    It is no problem whatsoever!
    Look here at my FAQ post:
    https://www.audioasylum.com/messages/tubes/253369/quot-tube-problems-quot-that-aren-t-tube-problems
    Item #7 deals with this issue and should completely clear up your concern. You can refer to that FAQ post for a lot of answers to common questions. Since you got the tubes from me you could have just dropped me a note and I'd have been happy to help as well!
    Post by Guest Fri Sep 07, 2018 6:23 pm
    ......Item #7 deals with this issue and should completely clear up your concern. You can refer to that FAQ post for a lot of answers to common questions. Since you got the tubes from me you could have just dropped me a note and I'd have been happy to help as well!
    Hi Jim!
    You are right on the money--both the description and pictures in your FAQ describe what I'm seeing.
    As I mentioned, they sound great and bias fine--I was just wondering if what I was seeing was perhaps an early indication of an emerging problem.
    Obviously I can rest easy.
    Now back to the music Smile Very Happy Very Happy
    Jay
      Current date/time is Sat Apr 27, 2024 1:13 am
