    Blue glow..
    Ernstmach
    Ernstmach
    Blue glow.. Empty Blue glow..
    Post by Ernstmach Fri Oct 13, 2017 8:38 pm
    I'm listening to some Johnny Winter vinyl. I notice one of my MKIII's KT88's has a blue glow  in the tube. I have it cranked up so I'm working the amp.
    So what does this indicate? The other Amp is not showing this.  Bad tube, Quad Cap? The glow looks like a reflection below the top plate of the tube onto the glass.
    Tried to take a photo but my Cannon 6D won't capture this phenomenom... Any thoughts?
    Tubes4ever
    Tubes4ever
    Blue glow.. Empty Re: Blue glow..
    Post by Tubes4ever Fri Oct 13, 2017 9:00 pm
    If the glow looks like it is on the inside of the glass, then it isn't a problem. The only blue glow you should worry about is if you see a glow in the open space between the cathode and plate. A glow on the inside surface of the plate where the electrons hit it is also normal.
    Post by sKiZo Sun Oct 15, 2017 6:30 pm
    Wouldn't lose any sleep over it. They've probably been doing it since day one and you're just now noticing it ...
    Blue glow.. Big-bottles-lit-003
    Post by Bob Latino Mon Oct 16, 2017 7:27 am
    A blue glow inside some tubes (usually output tubes) is harmless and fairly common. Read at the link below about the causes of "blue glow" in vacuum tubes.
    The Tubestore - blue glow explanation
    Post by deepee99 Mon Oct 16, 2017 5:42 pm
    Uff Da. I just round-filed a perfectly KT-88 for blue-flaming a couple of months ago. Thought it was a prelude to red-plating. Turns out it was the lighting and angle of view, I guess. Damn!
    Ernstmach
    Ernstmach
    Post by Ernstmach Mon Oct 16, 2017 7:19 pm
    Thanks for the replies everyone!
    Thanks for the link Bob.
    I learn lot's of new things with each visit here.
      Current date/time is Fri Apr 26, 2024 5:40 am
