Hi All.
Might Bob or anyone please be able to suggest what I should look at, when I get a big red glow in one of the EL34s in my VTA ST-70?
I purchased my VTA ST-70 kit (240v power transformer, both cap upgrades, with valves) through Bob in September 2012 and finally got it built after nine years! It is a gorgeous kit and it was a joy to build.
I double-checked my work and switched on and set the bias. Maybe the front right was a bit hard to get right because it seemed to change a bit - increasing over time. Anyway, for a couple of hours, the amp seemed to be running just fine and played very sweetly with my trusty Apple iPod as music source - through my Focal Chorus 714S 8 ohm speakers.
But I was still having a bit of an issue with what I regarded as a slightly unstable bias on the front right EL34, starting quite low when cool (perhaps 0.265v) and climbing up to and over (>0.400v) in a minute or so, sometimes seeming to continue to climb. So I was trying to set the bias at around 0.385v to be on the safe side. And that seemed to work OK.
Then once, after a couple of hours of total on-time, and a bit less than an hour of playing in this session (and when I thought the bias was fairly stable), I heard a small "plop" sound in the speaker along with the music, and the front right EL34 quickly started glowing bright red (very different from the small red filament glow). I switched off within maybe 10 - 15 seconds. I did try again, but noticed the same slightly unstable bias and after maybe a half hour this time, got the same "plop" and big red glow and switched off promptly. So I re-checked the wiring and the soldering on and around both right hand EL34 sockets, V6 and V7, and it all looked good. Tried again and got the big glow a third time - quite quickly this time - after maybe a few minutes of playing Beethoven at mid volume. So switched off in a few seconds. There is a perceptible darkening of the glass on the tube, but it is too hard to photograph. The glow seems to be happening quicker now, but I don't want to keep pushing it.
Something is NQR!
I would much appreciate suggestions for what to look for and/or check. I have a spare set of new JJ E34Ls but am loathe to put these in unless I've reduced the risk of the problem recurring with them too.
May I include a picture of my build. The cheap Chinese "VU" meters are illuminated via a diode and 470 ohm resistor from the heater circuit tapped off the front left valve socket V3, and take a signal feed from the 8 ohm speaker terminals via a diode, a 1.8k ohm resistor and a 10k ohm trim pot, using a circuit like this one - https://www.giangrandi.org/electronics/vu-meter/vu-meter.shtml. They're fun, and I can switch them off with the 3-gang switch on the left. I don't think these are contributing to my issue but I'm happy to hear other theories.
I apologize for my lack of tube knowledge, but I'm hoping that the above description is enough for folks to work with. If I can provide more, please let me know. Thank you for any assistance you can offer.
kind regards,
Simonism
Simon Murray
Melbourne, Australia
Something is NQR!
kind regards,
Simonism
Simon Murray
