Bob Latino wrote:Below are Al's photos of his M-125 build. Al, maybe you can tell us how you got the "M125" on the front face of the amp? The amps do not come with any lettering on the front. Also, those four BIG chassis supports on each amp are not stock. You did mention to me where you got them but I have forgotten?
Hello Bob,
Thank you so much for posting some of my photos. The amps are working fabulously. I've listened to them every day since I completed them and they have been burning in nicely.
With regards your questions:
1- The lettering was sourced from a local Michael's store and is merely adhesive backed vinyl. They have many different styles, fonts, and colors. It was easy to apply. I first placed a piece of tape on each amp to use as an alignment template.
I want to add smaller lettering for the On/Off switch and "L", "R", and "Bias". Michael's only had the smaller lettering imbedded in a clear backer/frame. That will not do , so I will source these on line soon.
2- The feet I used come from Cary Auido on line. The are called "Cary Soft Shoes" and are the isolation feet they use on their amps,preamps, and such. The cost $8.00 each, and although they come with mounting hardware, I found it to be inadequate for the M125 application and purchased longer machine screws, washers, and nuts from my local hardware store. These are the same "Shoes" that are on my AES Superamp MKii and AES AE-3 MKii that flank each M125.
3- One modification not shown in the photos is my addition of a SPDT toggle switch on the back of each amp to allow easier switching between 4 ohm and 8 ohm speakers. I have a reasonably large collection of speakers of both impedence values. I'm fortunate to have access to a nice machine shop and exceellent machinist where I work, and he placed the hole in the exact same location on each amp. The switches were sourced from Radioshack.
These are great amps. I wanted more tube power and by gosh I got it in spades.
Just yesterday I added a pair of the venerable JBL 250Ti speakers. These speakers are beasts and the M125's drive them with amazing authority. I am hearing new detail in some familiar recordings that I have never heard before with other amps.
Although I first fired up the amps with the Weber WZ68 SS rectifiers, a few days later I sourced a pair of NOS Mullard GZ33's from Kevin Deal at Upscale Audio. Upscale has a good commection of these tubes and they are priced at $99.98 each with free shipping. That's better than some of the questionable pedigree ones I saw for sale on that auction site. I've purchased from Upscale Audio previously and they are very trustworthy. I feel that the GZ33's offer slightly better, more defined bass extension than the WZ68's. I'll add the standard disclaimer: Your results may vary.
Thanks for everything Bob!
I'm sure that I made the right choice in building these amps. I'm considering building a second pair identically to this pair so that I can bi-amp some speakers. What a fun hobby!
Best Regards, Al.Wise
