+4
Tubes4ever
8 posters
    ST 70 High B+ voltage
    MZH000
    MZH000
    ST 70 High B+ voltage Empty ST 70 High B+ voltage
    Post by MZH000 Sat Jun 01, 2019 9:13 pm
    I upgraded my ST 70 rectifier to a new GZ34 from a 5U4 and replaced the can capacitor to 40-80-30-20 uf from Dynakitparts.com. I wired the capacitors as recommended (40 at rectifier, then 80 after choke, then 30, then 20). Line voltage is 122 volts. I get 500 volts at the rectifier cathode/40 uf lug after the tubes stabilize. The original Dynaco spec says it should be 435 volts. The original I assume had the line voltage at 117 volts. The combination of higher line voltage plus larger filter caps gets the B+ to 500, I assume. I'm running 45ma through the output tubes (KT77).
    Question: Is there any harm in keeping the voltage so high. My output tubes are KT77, so plate voltage can go to 800 volts. The filter caps are rated at 550 volts, except one which is at 525 volts. So I am below the max. Bias, as I said, is set for 45ma through each output tube.
    Also, my driver board is the classic VTA ST 70 board with CCS, running 3 12AU7's. The B+ going to the board is 445 volts, 25ma. It should be 375 volts. Any harm running at this level?
    ST 70 High B+ voltage Empty Re: ST 70 High B+ voltage
    Post by Bob Latino Sun Jun 02, 2019 9:18 am
    MZH000 wrote:I upgraded my ST 70 rectifier to a new GZ34 from a 5U4 and replaced the can capacitor to 40-80-30-20 uf from Dynakitparts.com. I wired the capacitors as recommended (40 at rectifier, then 80 after choke, then 30, then 20). Line voltage is 122 volts. I get 500 volts at the rectifier cathode/40 uf lug after the tubes stabilize. The original Dynaco spec says it should be 435 volts. The original I assume had the line voltage at 117 volts. The combination of higher line voltage plus larger filter caps gets the B+ to 500, I assume. I'm running 45ma through the output tubes (KT77).
    Yes - The original Dynaco ST-70 was designed to run on 115 - 117 VAC which was the line voltage of the 1950's - 1960's. Line voltages today are 120 VAC or slightly above. If an original Dynaco ST-70 amp's power transformer has to look at 122 VAC, all the amp's internal AC and DC voltages will be higher than normal, tube life will be noticeably lower and you may have troubles with your DC voltages exceeding the upper limit of the electrolytic caps. Yes - the driver board should look at 375 - 400 volts. Your 445 VDC on the driver board is much too high. Advice - Run your amp off a variac set to about 117 VAC on the variac's AC outlet. This should bring all AC and DC voltages on your amp down to normal levels. See link below for a variacs that may be used with your amp. Either 5 amp unit will work fine.
    Variacs sold at Circuit Specialists in AZ
    Post by Guest Sun Jun 02, 2019 4:42 pm
    MZH000
    MZH000
    Post by MZH000 Sun Jun 02, 2019 6:26 pm
    I installed the VTA board on an original ST 70 (other than KT77 output tubes) per instructions. The B+ going to the VTA board comes off a 2.2k resistor on the last two lugs of the capacitor can, as specified in the VTA board instructions. There is a voltage drop of 55 volts across the 2.2k resistor, so 25ma is going through it, which seems right on.
    The power transformer secondary measures 380 volts AC relative to ground. So that's about 5.5% higher than the 360 volts specified in the ST 70 manual. 122 volts is 5.5% above 115 volts, so that's consistent. The ST 70 specs say the voltage at the cathode should be 435 volts. 500 volts is 15% more, not 5.5%. So that is the mystery.
    Post by Guest Sun Jun 02, 2019 8:49 pm
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever Mon Jun 03, 2019 1:58 am
    MZH000 wrote:I installed the VTA board on an original ST 70 (other than KT77 output tubes) per instructions. The B+ going to the VTA board comes off a 2.2k resistor on the last two lugs of the capacitor can, as specified in the VTA board instructions. There is a voltage drop of 55 volts across the 2.2k resistor, so 25ma is going through it, which seems right on.
    Since the transformer high voltage secondary has a step up ratio of about 3, the B+ voltage will go up about 3 volts for every 1 volt increase on the primary. So, the 7 volt increase from 115 to 122 will give you about a 21 volt increase on B+. This is in line with your results. You may simply want to continue using the 5u4GB to keep your B+ lower.
    MZH000
    MZH000
    Post by MZH000 Mon Jun 03, 2019 4:09 am
    Correction: June 3, 2019. Tube loss is 17, not 10 volts. Vripple RMS halved due to Vripple is peak to peak.
    Upon further research: The 380 volts AC on the PT secondary I have is an RMS value. The peak voltage is sqrt(2) * RMS Voltage or 1.41*380 = 535 volts. In an ideal world where the DC voltage is fully filtered (no ripple), the DC voltage after rectification would 535 volts. BUT we need to subtract voltage loss of the tube, which for a GZ34 is about 17 volts. So the ideal fully filtered DC voltage would be 518 volts. Now we must subtract the ripple voltage, since in the real world we can't achieve 0 ripple. The ripple voltage can be calculated with the formula: Vripple = I/(f*C), where I is the current going through the circuit, f is the ripple frequency and C is the filter capacitor value in farads. So for my ST70: I = 205ma (4*45ma for the KT77s, 25ma for the VTA board), f = 120 and C = 40 uf (or 0.000040 farads). Plugging in the numbers we get Vripple = 42.7 volts. But this is peak to peak Vripple. RMS Vripple would be 42.7/(2*1.73) = 12.34 (we use 1.73 = sqrt(3), not sqrt(2), since the ripple wave is more sawtooth than a sine wave). So subtracting the ripple voltage from the ideal 518 volts = 518 - 12.34 = 506 volts, little over 1% above 500. Voila!
    See hyperphysics.phy-astr.gsu.edu/hbase/Electronic/rectct.html#c4 for details on the math.
    Post by Dave_in_Va Mon Jun 03, 2019 2:36 pm
    ST 70 High B+ voltage B41fJqy
    Post by Peter W. Mon Jun 03, 2019 3:01 pm
    MZH000 wrote:Upon further research: The 380 volts AC on the PT secondary I have is an RMS value. The peak voltage is sqrt(2) * RMS Voltage or 1.41*380 = 535 volts. In an ideal world where the DC voltage is fully filtered (no ripple), the DC voltage after rectification would 535 volts. BUT we need to subtract voltage loss of the tube, which for a GZ34 is about 10 volts. So the ideal fully filtered DC voltage would be 525 volts. Now we must subtract the ripple voltage, since in the real world we can't achieve 0 ripple. The ripple voltage can be calculated with the formula: Vripple = I/(f*C), where I is the current going through the circuit, f is the ripple frequency and C is the filter capacitor value in farads. So for my ST70: I = 205ma (4*45ma for the KT77s, 25ma for the VTA board), f = 120 and C = 40 uf (or 0.000040 farads). Plugging in the numbers we get Vripple = 42.7 volts. But this is peak Vripple. RMS Vripple would be 42.7/1.7 = 25 (we use 1.7 = sqrt(3), not sqrt(2), since the ripple wave is more sawtooth than a sine wave). So subtracting the ripple voltage from the ideal 525 volts = 525 - 25 = 500 volts. Voila!
    http://www.sowter.co.uk/rectifier-transformer-calculation.php
    Various configurations of power-supplies shown here.
    The idea behind the choke and caps is to eliminate that ripple. And it may be measured using the AC setting on your VOM. 25 Volts of ripple seems pretty high.
    MZH000
    MZH000
    Post by MZH000 Mon Jun 03, 2019 10:14 pm
    Thank you for the link to power supply configurations. So according to the first diagram (CAPACITOR INPUT FILTER FULL WAVE), the formula
    Vac = Vdc * 1.41
    With Vac = 380*2 and solving for Vdc:
    Vdc = Vac/1.41 = 760/1.41 = 539
    So there is a 39 volt loss to get to the observed 500 volt B+ voltage at the 40uf capacitor. The loss is a combination of rectifier tube voltage drop and ripple voltage.
    Post by Guest Mon Jun 03, 2019 11:26 pm
    Pillo69
    Pillo69
    Post by Pillo69 Tue Jun 04, 2019 12:44 pm
    1,4142 for solid-state rectifiers, 1,21 for valves.
    Post by Roy Mottram Tue Jun 04, 2019 4:11 pm
    you never say (or I missed it) if that 500v reading (and 445v to the VTA board) are at start-up or after waiting one minute for all tubes to draw full current.
    Those readings would be about right at start-up but after one minute should be down to 440-450vdc and 380-400vdc to the driver board.
    At any rate I would also recommend running the amp on a variac set to 115-117vac input and that should drop all those voltages around 6%, about 30v lower.
    You may need to change the 2.2K 3w resistor on the quad cap to 3.3K 5w if you're still getting over 400vdc to the driver board, that will drop an extra 25v.
    MZH000
    MZH000
    Post by MZH000 Tue Jun 04, 2019 4:24 pm
    tubes4hifi wrote:you never say (or I missed it) if that 500v reading (and 445v to the VTA board) are at start-up or after waiting one minute for all tubes to draw full current.
    Thanks for the reply. I said in my original post:
    "I get 500 volts at the rectifier cathode/40 uf lug after the tubes stabilize."
    So the readings are at steady state with the amp all warmed up. Not much change after playing an hour.
    Variac is on order and will see how things change with a lower line voltage.
    Thanks again.
    Post by Guest Tue Jun 04, 2019 4:33 pm
    pichacker
    pichacker
    Post by pichacker Wed Jun 05, 2019 7:48 am
    Pete, so you mean a redesign of the power transformer to include a primay tap or two? Back to the old days with a line voltage selector switch Smile
    Post by Guest Wed Jun 05, 2019 9:47 am
    pichacker
    pichacker
    Post by pichacker Wed Jun 05, 2019 10:07 am
    Pete, it's just that I read a lot of threads about the line voltage today being higher than it used to be and people are using buck transformers/variacs. If the transformer had a 120/125v tapping then this would bring the secondary voltages back to levels where an external device was not necessary. Steve
    MZH000
    MZH000
    Post by MZH000 Wed Jun 05, 2019 11:16 am
    pichacker wrote:If the transformer had a 120/125v tapping then this would bring the secondary voltages back to levels where an external device was not necessary. Steve
    Seems like the new replacement power transformers from various vendors have the primary designed for 120 volts. Can anyone verify from experience?
    Post by Peter W. Wed Jun 05, 2019 12:47 pm
    As usual....
    a) Back in the day, a number of higher-end radios did have multi-voltage switches on board, typically from 110 V to 115V, but some few from 120 V to 125 V. A nice touch when that same radio would cost a month's salary for the typical worker. This option largely 'went away' when it became clear that most (tube based) equipment did not care about low-voltage as much as it did about high-voltage - so the 120 V standard became the norm. Note: Motor-loads like high voltage, standard transformer-based electronics do not and resistance-based devices do not.
    b) These days, voltage can vary between the tariff limits hour-by-hour as power-companies try to send sufficient power through an obsolete grid to meet demand. We are lucky as we are in an old and established neighborhood and our sub-station is nearby. So, we are generally at 118 V summer/winter/day/night. Most of North America is not so lucky.
    c) Manufacturers will not/do not want to make on-board accommodations to this problem - it adds cost, complications and opportunities for consumer misinformation and equipment damage that could fall back on them. At the same time, most modern equipment uses switching power-supplies able to handle about anything from 90 V to 240 V. But tube-based stuff with massive power-transformers on-board, not so much.
    d) Leaving the end-user with three basic choices being a bucking transformer., a variable transformer and, finally, a line conditioner.  Of the three, the bucking transformer is  fixed-value device with some appeal inasmuch as running stuff a few volts low is rarely a problem. But, it is fixed. The variable transformer is user-adjustable to a wide range of wall-plate voltages and can also boost on those rare occasions when that is necessary. But, it is bulky, and unless considerably over-rated, subject to hum. Add to this the fact that a well-made (domestic) devices is costly relative to a Pacific-Rim devices of dubious quality.  Leaving the Line Conditioner as being a set-and-forget device that will provide a layer of protection, as well as accommodate both low and high wall-plate voltages. Also the most costly. Relative to the equipment and tubes that go into it, however, not all that costly.
    You pays you money, you takes you chances.
    Pillo69
    Pillo69
    Post by Pillo69 Wed Jun 05, 2019 3:27 pm
    I don't understand the problem with the tensions and the variac.
    I sent to rewind the original transformer for 240v (voltage in Europe is said to be 220v), and the secondary oversized amperage.
    I have no problem, the transformer runs cold, total for 30 euros rewind.
    MZH000
    MZH000
    Post by MZH000 Fri Jun 07, 2019 12:14 am
    So I got the variac. I set it so that the secondary of the PT is 360 volts AC. The variac reads 116 volts at that setting. The following voltages were observed after setting the bias at 45ma per tube:
    B+ at GZ34 cathode/40uf cap: 472 volts
    B+ after choke (plate B+): 469 volts
    B+ at VTA board: 414volts
    Fillament: 6.37 volts AC
    At line voltage at 122 volts:
    B+ at GZ34 cathode/40uf cap: 500 volts
    B+ after choke (plate B+): 497 volts
    B+ at VTA board: 442 volts
    Fillament: 6.78 volts AC
    Note that in the above, the voltage drop across the choke is 3 volts. The ST-70 manual says it should be 20 volts! So the choke may be the culprit. I'll get a new one and try it. Stay tuned.
    Post by Guest Fri Jun 07, 2019 12:54 am
    MZH000
    MZH000
    Post by MZH000 Fri Jun 07, 2019 12:02 pm
    Well...I'm embarrassed to say that the high B+ voltage problem was caused by my misreading of the bias setting voltage. Instead of setting the KT77 cathode voltages to 0.45 volts, I was setting them to 0.045 volts! DUH! Somehow I missed seeing the leading 0 on my digital multimeter. In any case my apologies for wasting everyone's time. I appreciate all your help.
    What led to this discovery was the low voltage across the choke of only 3 volts. Following PeterCapo's advice, I measured the resistance of the choke and got 62 ohms, exactly what it should be. So that meant the current going through it was only 48ma. How could this be when the KT77's were supposed to be drawing 45ma each? Well, as I said above, they were drawing 1/10 of that value! 4.5ma each times 4 is 18ma. That plus 25ma for the VTA board results in 43ma, within rounding error of the measured 48ma. I was running the amp more like a class B amp.
    Now the voltages are sane. At 122 AC line in, the secondary is at 373 AC. The B+ at the GZ34 cathode/40uf cap is 447, after the choke is 435, and at VTA B+ is 380.
    Post by Guest Fri Jun 07, 2019 12:13 pm
      Current date/time is Sun Apr 28, 2024 6:11 am
