    ST-70 or ST-120 in Kit form
    eminence1963
    eminence1963
    ST-70 or ST-120 in Kit form Empty ST-70 or ST-120 in Kit form
    Post by eminence1963 Sun Jun 16, 2019 2:03 pm
    Question 1 ST70 or 120 for Hersery 3's? I do like my music loud sometimes. Currently running Prima Luna Dialogue 5 on the 3's. Sounds great low to mid volume, but run it hard and it gives up the ghost starts to scream and music falls apart.
    Question 2 The 120 does not run KT77's reliably or can but shortens the tube life is this true?
    ST-70 or ST-120 in Kit form Empty Re: ST-70 or ST-120 in Kit form
    Post by deepee99 Sun Jun 16, 2019 3:16 pm
    First question to answer your question:
    What's the efficiency of your speaks? I'm guessing being Kliipschs you're at 90 dB or better.
    If >90-91 dB. the ST-70 is all you need to fill a medium-sized concert hall. Another good case for them is their use of 6CA7/EL-34 output tubes, which NOS go for $100-$200 a quad.
    OTOH, the -120, built around the 6550/KT-88, will give you quite a bit more gain but uses the far more expensive KT-88/6550 outputs. (
    Driver tubes are the same for both amps. I use octal 6SN7s in both my ST-70 and ST-120.
    In the purest of all possible worlds, get two ST-70s with a gang of 8 EL-34- 6CA7-type outputs and use them as monoblocks. Those eight good EL-34s will cost you about one-fourth to one-half the price of the Gold Lion KT-88/Tung-Sol 6550 equivalents. Initial expense for the two -70s is higher, but down the road you'll save a fortune in tubes of equal sonic ambrosia.
    Just my thoughts, and I have both of these amps on-line and amply stocked with "pre-blight" outputs.
    Another consideration is your output transformers. The ones Bob uses are superb for the price, but if you're going all-out use Lundahls instead. Another $600 or so, but definitely worth it. I took a flyer on Holger's recommend to do this upgrade and am very glad I did.
    Post by Bob Latino Sun Jun 16, 2019 4:22 pm
    eminence1963 wrote:Question 1 ST70 or 120 for Hersery 3's? I do like my music loud sometimes. Currently running Prima Luna Dialogue 5 on the 3's. Sounds great low to mid volume, but run it hard and it gives up the ghost starts to scream and music falls apart.
    The Prima Luna Dialog 5 is a 42 watts per channel amp. If that amount of power does not do it for you, then the 35 WPC VTA ST-70 won't do it for you. I recommend that you use a VTA ST-120 amp in your situation. The 60 WPC from the ST-120 will run your Heresy's up to higher volume levels than the Dialog 5. With the VTA ST-120, I only recommend the use of 6550, KT88 or KT120 output tubes. The Dialog 5 is supposed to be able to also use EL34, KT66, KT77 and 6L6 tubes but these 4 tubes are nearly always used in 35 WPC amps. Yes > If you try to use the EL34, KT66, KT77 and 6L6 tubes in the ST-120, they probably will have a shorter than normal life. They also may not bias properly.
    eminence1963
    eminence1963
    Post by eminence1963 Sun Jun 16, 2019 5:43 pm
    Thanks Bob I already ordered up the upgraded coupling caps and attenuator pot upgrade as well already from you this weekend. After reading and searching extensively for my next suitable amp that I can afford It came down to your ST70 ST120. Looks like the 120 is the one I need to buy. That will happen shortly as I waiting for a refund from the amp that I just bought that did not fit my need. If I purchase a amp from you do you sell individual parts for the amp in question. Say I need just a cap or a resistor for instance?
    Post by Bob Latino Sun Jun 16, 2019 6:03 pm
    Yes - I keep extra stock of all the parts here for all the VTA amps. You get a 1 year warranty on all the parts in the amp. If you get the tubes from me, there is a (standard tube industry) 90 day warranty on all the tubes.
      Current date/time is Mon May 06, 2024 4:50 pm
