The Dynaco Mark II was Dynaco's first product which came out in 1955. In 1957 Dynaco upgraded the existing Mark II (50 watts using EL34 tubes) into a Mark III (60 watts using KT88 tubes). Many Mark II users wanted to upgrade their amps to Mark III's so Dynaco sent out this bulletin to all their Dynaco dealers. The bulletin listed the steps that would need to be taken to upgrade their amps. In general you had to upgrade some capacitors and alter the bias system to be able to crank in more negative DC to control the newer KT88 output tubes. You also had to add a choke and use a 5AR4 in place of the Mark II's 5U4. Check out the complete bulletin below which gives more detail on the conversion.
