+3
breading
7 posters
    tubes4hifi SP14 and Psvane CV181 Tii tubes
    breading
    tubes4hifi SP14 and Psvane CV181 Tii tubes Empty tubes4hifi SP14 and Psvane CV181 Tii tubes
    Post by breading Thu Aug 15, 2019 1:37 am
    Hello,
    Just a word of caution to those who may be considering the recommendation of many owners to consider upgrading their tubes4hifi SP14 tubes to the Psvane CV181T Mark II.
    The tubes received universal high marks from the reviews I have seen.  I gulped and opted for the top of the line, buying the Grade A quality from Grant Fidelity at $290 for the matched pair.
    Sound is extraordinary.  Tubes appear to be of the highest quality.  However!!
    Unfortunately, the tubes are too tall to fit in the standard chassis.  They will not clear the top lid.
    My research prior to purchase failed to reveal this as a problem and I am now faced with selling the tubes at a substantial loss, using the preamp without the lid, or drilling holes in it so the tubes will clear the lid.  None of those are considered satisfactory solutions.
    Has anyone else had this experience, and if so how did you deal with it.
    See the attached link for photo.  I have placed the chassis lid upside down behind the tubes so you can see the lack of clearance.
    https://postimg.cc/XZjL4C50
    tubes4hifi SP14 and Psvane CV181 Tii tubes Empty Re: tubes4hifi SP14 and Psvane CV181 Tii tubes
    Post by Peter W. Thu Aug 15, 2019 3:07 pm
    http://www.apexjr.com/images/RtAngle9pin.jpg
    Would there be clearance for a device such as the one linked?
    Alternately, an Octal Relay socket mounted on-edge, hard-wired to the PCB? JB-Weld would handle the mounting nicely if there were enough space.
    Post by deepee99 Thu Aug 15, 2019 3:39 pm
    Not their fault in this case, but give Grant Fidelity a very wide berth. Ask around . . .
    New2Tubez
    Post by New2Tubez Thu Aug 15, 2019 4:44 pm
    How short could the board stand-offs be?
    Would this give you clearance? OR cause other issues?
    mijohn
    Post by mijohn Thu Aug 15, 2019 9:02 pm
    As the CV181's appear to be only a couple of mm too tall you could add an extra nut or two as spacers when screwing the lid on or using shorter PCB stand-offs or making them shorter by sawing off bit of height, ensuring there is enough clearance from the base plate of course.
    breading
    Post by breading Sun Aug 18, 2019 1:53 pm
    Thanks for all the good suggestions. I have decided to opt for reducing the height of the stand-offs as the best solution. I have ordered 1/4 inch stand-offs from Mouser to be delivered tomorrow. Will post results once I see if that will do the job.
    Post by Roy Mottram Mon Aug 19, 2019 8:30 pm
    PeterW,
    first, your post is totally irrelevant, as those are 9 pin sockets, and we are talking about octal tubes.
    second, I'm pretty sure you don't have an SP14 (because I've seen you answer about 100 other posts about products or parts you don't have),
    so why are you even trying to give advice about something you know nothing about?
    Please reserve your comments and answers to questions and problems you are personally experienced with.
    breading
    Post by breading Tue Aug 20, 2019 4:01 pm
    In Roy's defense, I have never received less than outstanding service from him on any number of issues encountered over the years.  On more than one occasion he has performed repair work at no cost, provided free replacement parts, and offered superb service and advise.
    As for PeterW, I thank you for your suggestion. I am sure it was given with the best intentions.
    As for my original problem with the Pvsane CV181 in my SP14, the shorter stand-offs (1/4") I ordered from Mouser worked to solve the problem.  The tubes have about an eighth of an inch clearance.  I will hope that the tubes will not suffer from being that close to the chassis lid.
    Bruce
    Ernstmach
    Ernstmach
    Post by Ernstmach Tue Aug 20, 2019 7:28 pm
    "your post is totally irrelevant, ( actually Roy, it isn't)
    "as those are 9 pin sockets, and we are talking about octal tubes."
    Explains a couple more things.....
    Post by deepee99 Tue Aug 20, 2019 7:48 pm
    Ernstmach wrote:"your post is totally irrelevant, ( actually it isn't)
    BUMP
      Current date/time is Sat Apr 27, 2024 12:36 am
