New power tubes might be what's needed. Don't reuse a tube that has redplated.B&WTube wrote:I hate to bring it up again, but I am having issues with the same back right socket again. I was quietly listening to music, and heard heavy distortion and the tube was glowing red hot. I cut the amp off for a while, turned the bias all of the way down, and then fired it back up. No problems after 30 minutes. So I added the bias, but it will not go high enough- with the highest bias pot position i can only get to .240 Other GL kt77's are at .450).
After the last round of issues put in a new tube, tested all the resistors around this socket as well as the ground- everything was within spec. I also re-soldered everything related to the socket. Life has been good for the last almost 3 months. Amp had been on for 2 hours before this. Anyone have any advice?
+3
B&WTube
Dale Stevens
7 posters
Bias not stopping to zero
peterh- Posts : 1833
- Post n°26
Re: Bias not stopping to zero
B&WTube- Posts : 40
- Post n°27
peterh wrote:New power tubes might be what's needed. Don't reuse a tube that has redplated.B&WTube wrote:I hate to bring it up again, but I am having issues with the same back right socket again. I was quietly listening to music, and heard heavy distortion and the tube was glowing red hot. I cut the amp off for a while, turned the bias all of the way down, and then fired it back up. No problems after 30 minutes. So I added the bias, but it will not go high enough- with the highest bias pot position i can only get to .240 Other GL kt77's are at .450).
I swapped it out with a new tube, and got the bias set back where it should be.
The concerning part is that this is the 3rd red plating of this socket since I built it in August of 2019. 3 Tubes in 7 months in only the back right socket indicates I have a problem.. BUT, if the resistors and the grounds are fine, and everything on that socket has been re-soldered- I don't know where to look for the issue.
- Post n°28
B&WTube wrote:peterh wrote:New power tubes might be what's needed. Don't reuse a tube that has redplated.B&WTube wrote:I hate to bring it up again, but I am having issues with the same back right socket again. I was quietly listening to music, and heard heavy distortion and the tube was glowing red hot. I cut the amp off for a while, turned the bias all of the way down, and then fired it back up. No problems after 30 minutes. So I added the bias, but it will not go high enough- with the highest bias pot position i can only get to .240 Other GL kt77's are at .450).
If this is a VTA-70 the grid resistors for power tubes are 270k in my documentation. That is fine
( or at least within the book ) for EL34. But it's outside spec for KT77, the KT77 in fixed bias and >25w
stipulates at most 250k as grid resistor. This might explain the tendency to have the tubes go red.
Get EL34 or reduce the grid resistors to 100k.
/PS
as a security i would also recommend "screen stoppers" installed, soldered at the tube socket pin4.
Carbon comp 1/2w 1kohm will be fine. This will prevent parasitical high frequence oscillations that
is very hard on tubes.
/DS
B&WTube- Posts : 40
- Post n°29
peterh wrote: If this is a VTA-70 the grid resistors for power tubes are 270k in my documentation. That is fine
/PS
/DS
Interesting. Bob Latino is the one who said KT77's are ok in his VTA-70, and then provided the recommended bias of .450 . However, I am showing 270k resistors on my VTA board instructions (if I am looking at the right thing). If it is beyond spec, I wonder if I am pushing it even further beyond the envelope with my Weber SS rectifier and 12BH7A signal tube. Great insight- thank you!
B&WTube- Posts : 40
- Post n°30
I gave up on the amp for a while, and now I am back at it. I was just measuring things (not totally knowing what I am doing), and I discover that Pin 6 on the VTA board for the V6 tube socket (front right), doesn’t show any resistance. All other Pin 6’s at the board and on the socket measure around .295 @ the 2M setting in my multimeter.
I re-soldered a new wire and still no reading. I’m not sure what this indicates, but it seems something isn’t right. Thoughts?
Roy Mottram- Admin
- Post n°31
sorry I only check in here about once a week . . .
So, there is only one connection to pin 6, it goes to the driver board.
Since all the other output tubes measure a certain amount from pin 6, so should the one that reads bad.
So the problem would either be a bad solder connection on the wire (either end) or something like a bad solder connection
on the driver board, for that output only. Simple to check and compare.
MechEngVic- Posts : 106
- Post n°32
B&WTube,
Any progress on your issue? Had recent trouble similar to yours with my Dynaco ST-70 Series II, was causing me trouble for months and several tubes, then just settled into the rare half second buzz. No more arcing or red-plating. I have several mods waiting in the wings if the problem comes back including lowered value coupling caps, carbon comp screen resistors, carbon comp control grid resistors (solder directly to pin 5), and two cl-80 thermistors for a softer start up.
