    PA060 No Load secondary HV tolerances
    BCROW
    PA060 No Load secondary HV tolerances Empty PA060 No Load secondary HV tolerances
    Post by BCROW Fri Mar 06, 2020 6:47 am
    Hello,
    Does anyone know the acceptable tolerance for the high voltage secondary portion of the PA060 type power transformer in no-load condition?
    I see specs show 360 55 0 360 but mine is measuring 345 65 0 355 with the specified primary voltage.
    How critical are these voltages in the ST-70 and if so what should I watch out for?
    All the low voltages are spot on.
    Any suggestion/schematic for a load condition test that would somewhat replicate loads in the ST-70?
    Thanks!
    PA060 No Load secondary HV tolerances Empty Re: PA060 No Load secondary HV tolerances
    Post by Guest Fri Mar 06, 2020 6:01 pm
    BCROW
    Post by BCROW Fri Mar 06, 2020 6:06 pm
    Hi Peter,
    AC Mains is stable @231V. The power transformer is a 230 volt model from a supplier here in Europe.
    Post by Guest Fri Mar 06, 2020 6:21 pm
    BCROW
    Post by BCROW Sat Mar 07, 2020 4:03 am
    Thanks, Peter
    Yes, that was the plan.
    Maybe someone has a PA060 laying around or still unbuilt that could post their no-load readings but will proceed with the build and see how it goes. Smile
    BCROW
    Post by BCROW Sat Mar 07, 2020 10:09 am
    From one of Bob Latino's posts about testing iron:
    1. For the power transformer ... Connect the two BLACK wires to a 120 volt AC power source ..
    Measure the AC voltage across the two RED wires > 700 - 760 VAC
    Measure the AC volatge across the two GREEN wires > 6 - 7.5 volts AC
    Measure the AC voltage across the two BROWN wires > 6 - 7.5 volts AC
    Measure the AC voltage from the RED/BLACK wire to the RED/YELLOW wire > 55 to 60 volts AC
    Measure the AC voltage from the BROWN/YELLOW to the RED/YELLOW - 3 to 4 volts AC
    Measure the AC voltage from the GREEN/YELLOW to the RED/YELLOW - 3 to 4 volts AC
    So guess pretty close, a bit high on the 50-60V but that should drop when there's a load.
    Post by Guest Sun Mar 08, 2020 7:50 pm
    BCROW
    Post by BCROW Mon Mar 09, 2020 1:23 am
    Peter,
    Here's the source thread. Looks like unloaded to me.
    https://dynacotubeaudio.forumotion.com/t2111-testing-st-70-iron?highlight=transformer
      Current date/time is Fri Apr 26, 2024 4:46 pm
