I am looking at the inside of a PAS 3X So far I have taken some pictures and am thinking about how to best restore some of its possible problems and just keep it going. Saw a board for replacing the cans just looking for peoples experience and ideas. Believe Triode Electronics does the board Sure others have it or similar.? Leave it at that for now. Do not know how to post my pics yet or I would.
PAS 3X Dynaco
Guest- Guest
Re: PAS 3X Dynaco
peterh- Posts : 1833
Re: PAS 3X Dynaco
Or get one of the ready made boards if you find it difficult to assemble one.PeterCapo wrote:If you are referring to a "cap board" that replaces the quad section capacitor as well as the filament supply, yes they perform well. Trouble is, they can be difficult to get installed and working well. It has a number of parts that would need to be assembled and then wiring it in could result in problems. It is more straightforward to install a new quad section capacitor, if you really need one.
What kind of problems are you having with your PAS-3X? Are you sure it is a PAS-3X you have and not a PAS-3? This document will help to sort that out: http://www.audioregenesis.com/documents/Dynaco%20PAS%203%20or%203X.pdf
Benefits of these boards is that :
- costs less then a new quadcap
- it also replaces se rectifier and it capacitors
The end result for future generations is that all caps are ordinary boardmounted
types widely avaliable and no special versions.
