+16
markeby
cddeluca
irishsgd
HiGHFLYiN9
DavidR
Tom
ramon68
Dale Stevens
buchela
pedrocols
Midwestside
20 posters
    Made my own custom power strip.
    Made my own custom power strip. Empty Made my own custom power strip.
    Post by corndog71 Fri Jul 17, 2020 2:02 pm
    Just wanted to share my new creation.  For years I’ve been juggling several power strips to handle everything in my rig.  I had built a couple of buckers before but wanted something that would handle everything.  So with the free software by Front Panel Express I made a plate that everything would mount to.  I got the biggest 6.3V transformer I could find, Triad F22A, to make sure there was no current restriction.  I was inspired by Shunyata power strips.  15A hydraulic magnetic circuit breaker/ power switch.  Heavy duty Hubbell inlet and hospital grade outlets.  (I got a deal on the orange ones, plus I like the color.). 12awg wired internally.  Hammond 12x10x3 box.  No filters.  It has a short 10awg power cord to the wall.  Meters can be turned off.
    The first thing I noticed when I fired everything up was the utter lack of noise.  My system is dead quiet!  Cost a lot less than the Shunyata!
    Made my own custom power strip. 50123478952_f88c4200d0_cCustom Power Strip with bucking transformer.
    Made my own custom power strip. 50123254726_8fc9ed20ac_cCustom Power Strip with bucking transformer.
    cddeluca, 10-E-C, rustybutt, DavidR and knotscott like this post
    Made my own custom power strip. Empty Re: Made my own custom power strip.
    Post by peterh Fri Jul 17, 2020 2:15 pm
    Very nice !
    Midwestside
    Midwestside
    Post by Midwestside Fri Jul 17, 2020 7:08 pm
    Totally Awesome!
    Post by Dave_in_Va Fri Jul 17, 2020 7:57 pm
    You should market it as kit.
    It looks great!
    pedrocols likes this post
    pedrocols
    pedrocols
    Post by pedrocols Fri Jul 17, 2020 10:32 pm
    Yes definitely should offer it as a kit.
    Midwestside
    Midwestside
    Post by Midwestside Fri Jul 17, 2020 10:33 pm
    I want one!!
    buchela
    Post by buchela Sat Jul 18, 2020 2:32 am
    Wow, good layout, sturdy, Hubbell Hospital grade outlets with isolated ground. Impressive, But, after all the trouble, why not spec'd to 20 amps ?. Fantastic job.
    DavidR likes this post
    Post by Bob Latino Sat Jul 18, 2020 8:59 am
    Hi Rob,
    What Pedrocols and Dave_in_Va has said .. With voltages in the USA all over the place, you should consider offering your custom power strip as a "kit". You should do a cost analysis of the parts in there and add on how much you feel is a fair profit margin on the strip. You then write up a set of instructions on how the strip should go together with maybe a wiring diagram. I bet these would sell on Ebay ...
    pedrocols and DavidR like this post
    Dale Stevens
    Post by Dale Stevens Sat Jul 18, 2020 10:07 am
    Check out Rob's Flickr slide show; Just click on the right of his photo. Rob, that is perfect. Dale
    ramon68
    Post by ramon68 Sat Jul 18, 2020 12:34 pm
    I'd buy the kit - or the plans for the bucker/conditioner to build it myself if you don't want to go into business.
    Post by corndog71 Sat Jul 18, 2020 1:01 pm
    Wow!  Thanks for the kudos.
    Sadly, those panel meters I used are very hard to find at the moment.  Amazon ran out and doesn’t know when or if they’ll be back.  I could redesign the plate minus the meters which would save a few bucks but wouldn’t look as cool.  Otherwise I’d have to order a different panel meter which also means back to the drawing board.
    Honestly, I’m not much of a business man.  I’d rather share my design.  Most of the parts aren’t difficult to source.
    I guess I could’ve made it all 20A but I just figured most people wouldn’t need it. I didn’t.
    MechEngVic likes this post
    Post by Dave_in_Va Sat Jul 18, 2020 1:54 pm
    Can we get a gut shot to see how complicated the wiring is?
    Thanks.
    Post by corndog71 Sat Jul 18, 2020 6:50 pm
    Dave_in_Va wrote:Can we get a gut shot to see how complicated the wiring is?
    Thanks.
    You sure can!
    Made my own custom power strip. 50127604557_0ccbc79553_cCustom Power Strip
    aguaazul and DavidR like this post
    Post by Dave_in_Va Sat Jul 18, 2020 7:24 pm
    Man, looks great.
    I have a primitive version of that, i. e. a power strip plugged into a bucker.
    Yours is so much cooler. And you're right, the meters are really the crowning touch.
    Tom
    Post by Tom Sat Jul 18, 2020 9:10 pm
    Dang! Nice!
    DavidR
    DavidR
    Post by DavidR Thu Jul 23, 2020 4:45 pm
    Very nice!
    Can you get those voltmeters to do tenths of a volt ? i.e. 117.3 for example
    buchela
    Post by buchela Thu Jul 23, 2020 5:15 pm
    DavidR : Those are a three digits display only. I've seen those with fractional voltage on b bay, but you pay a lot for the extra digit
    HiGHFLYiN9
    HiGHFLYiN9
    Post by HiGHFLYiN9 Thu Jul 23, 2020 5:27 pm
    Great work, nice and clean! cheers
    irishsgd
    irishsgd
    Post by irishsgd Thu Jul 23, 2020 5:48 pm
    Very nice! I would be interested in a kit.
    cddeluca
    Post by cddeluca Thu Jul 23, 2020 5:57 pm
    corndog71 wrote:Wow!  Thanks for the kudos.
    I don't think the meters are a sticking point - you could configure it with two test points and periodically monitor voltages with a DVM, or even plug a pair of $5 meters in permanently.
    Excellent work.
    markeby
    markeby
    Post by markeby Thu Jul 23, 2020 6:51 pm
    That is a really nice configuration. I designed a digitally controlled audio system power controller for church sound systems and I use one to sequence my stereo system correctly (Turntables, then pre-amp, then power amp turn on in that order and off in the opposite) with programmable time delays and even 12 volt outputs for vent fans so that the power amp shelf doesn't overheat in our hot Texas summers. I will post in in another thread soon. That combined with what you did hear would make both a lot better. Also, the Arduino makes meter control really easy. I have a design for that but never implemented it in production.
    DavidR
    DavidR
    Post by DavidR Thu Jul 23, 2020 7:05 pm
    @corndog71 Does The reduced AC fluctuate if the Main AC changes or does it hold it steady at 117V ?
    Post by corndog71 Thu Jul 23, 2020 7:27 pm
    DavidR wrote:@corndog71 Does The reduced AC fluctuate if the Main AC changes or does it hold it steady at 117V ?
    No, the transformer drops the main voltage by 6 volts regardless of what it’s at. There is no regulation and no filter.
    Post by Roy Mottram Thu Jul 23, 2020 8:10 pm
    very very cool, I think I'll research doing a kit but with an internal 8A transformer, that would be enough to run an amp, preamp, and two sources, I'm guessing around $200 for parts,
    the most expensive part is the custom machined top aluminum plate, could also save alot of $$ by making a smaller one with just an internal transformer, output voltage meter,
    and just two outlets to plug strips into, probably under $100.
    payuppal likes this post
    Post by corndog71 Thu Jul 23, 2020 9:47 pm
    These were my goals:
    1. One box. No extra strips. Been juggling multiple strips and filters for years and they look cluttered and messy and I’m tired of them.
    2. Heavy duty inlet and outlets. They have better grip and will hold up longer. I currently have 8 things to plug in but with different amps or monoblocks I’ll need those extra outlets. Also better spacing of the outlets to allow for wall warts.
    3. Many high end manufacturers use overrated transformers and base that on sound quality. The 20A transformer may be overkill but it also just gives me peace of mind that it won’t ever be a limiting factor. And it’s not that much more money.
    3. Cool meters built in. No extra plug in meters or needing to keep a separate voltage meter nearby.
    4. High quality circuit breaker.
    5. Less cost than the competition.
      Current date/time is Wed May 08, 2024 3:48 am
