    VTA ST70 wiring for bias seems wrong
    rollinlikemarcbolan
    VTA ST70 wiring for bias seems wrong Empty VTA ST70 wiring for bias seems wrong
    Post by rollinlikemarcbolan Mon Jul 20, 2020 10:47 am
    Hi all, brand new member.  I've had Dynaco equipment for years, but I've always hired technicians for repair and upkeep.  I've decided to learn some rudimentary electronics during the "Covid break"...   I appreciate your patience, as I'm only taking my first steps into this world!
    I traded a pair of Dynakit MKiii mono blocks for a nice VTA ST70.   It worked fine except for occasionally blowing fuses more and more frequently.  After some digging around online, I decided to replace the rectifier tube with a SS one from Weber.  I fired it up and it worked.
    After adding the SS rectifier, I wanted to bias the tubes. I noticed that only one bias pin on the front socket was reading any voltage.  Everything I see says there should be two, one for each tube... from my understanding, one of the luxuries of the updated board is so that you can bias each tube individually!
    When adjusting both pots on one channel, I see the voltage goes up and down.  It seemed like both tubes are hooked up to one pin on the front socket.
    I opened up the amp, and sure enough, the front bias socket only has one wire heading to the tubes, which appear to be connected.  Has anyone seen this done before?  I really would rather have it set up the "right" way... but I'm afraid i'm not willing to experiment on this valuable piece of equipment.  Any advice is much appreciated.
    I've attached a photo, hopefully it makes sense.  Thanks a bunch.
    EDIT: I'm not allowed to post a photo for a few days. I'll try again soon.
    Last edited by rollinlikemarcbolan on Mon Jul 20, 2020 10:51 am; edited 1 time in total (Reason for editing : image not displayed)
    VTA ST70 wiring for bias seems wrong Empty Re: VTA ST70 wiring for bias seems wrong
    Post by peterh Mon Jul 20, 2020 11:19 am
    There should be two wires to each front socket. Both are connected to the cathode of each tube.
    The original builder must have forgotten this detail.
    Do connect the second one on each side to a free outlet pin, i think pin 4 ( opposite the working )is
    recommended in the build instructions.
    And it't vital that both are connected since you have no clue of the back tubes bias without this.
    rollinlikemarcbolan
    Post by rollinlikemarcbolan Mon Jul 20, 2020 12:00 pm
    peterh wrote:There should be two wires to each front socket. Both are connected to the cathode of each tube.
    It looks like whoever wired this board did this intentionally, as both tubes per channel are wired together for one bias. As soon as I'm allowed to post photos, I'll show what I mean.
    Thanks for your reply
    Post by Roy Mottram Thu Jul 23, 2020 9:50 pm
    you can run a wire from each output tube to the front test sockets. That probably wasn't done.
    Refer to the VTA wiring diagram here . . . . www.tubes4hifi.com/VTA70wiringdiagram3.jpg
    There should be a 10 ohm resistor on each output tube cathode to ground so that you can measure the bias.
    Set for 40ma per tube which is 400mv, without music playing. Adjusting any one tube will have a slight effect on the others,
    but going back and forth 2-3 times and they should all be in the 390-410 range.
      Current date/time is Wed May 08, 2024 10:17 am
