I am new here but have owned Dynaco equip for decades. I have a Panor Stereo 80 tube amp. It developed a short circuit and burned one ot the circuit boards. My fixer needs a picture of the circuit board to either make a new one or maybe there are parts available. I le the amp and want it back in operation. Thanks I can send pics of the board. I believe it is the power supply. It is in the shop as I write this.
Pictures for circuit bards Dynaco Stereo 80 tube Panor
rdelong1- Posts : 1
stewdan- Posts : 231
Hi rdelong1 --- you might get more feedback if you moved your appeal for pictures out of the pictures area and into the Forum's Basket where there is major discussion of questions or problems.
For what it is worth, there are schematics but no pictures of the boards in the Owners/User Manual for the Panor ST-80.
If you need the manual one is available at the following URL:
www.brainfartz.com/images/Stereo Stuff/dynaco/dynaco-st80-manual.pdf
note the blank space between Stereo and Stuff!!!
There is also other stuff on-line ..... do a GOOGLE search on "dynaco Panor st-80"
I found schematics and pictures of the exterior of your amp, but no picture of the interior circuit boards.
(BUT THEY MIGHT BE BURIED SOMEWHERE BELOW WHERE I LOOKED)
Hope this helps,
Stew
Hope this helps,
Stew
boeingpilot- Posts : 39
Just for one that also has PC burn. Happened by one of the relays, is that where your damage is?
aguaazul- Posts : 136
stewdan wrote:Hi rdelong1 --- you might get more feedback if you moved your appeal for pictures out of the pictures area and into the Forum's Basket where there is major discussion of questions or problems.
Hope this helps,
Stew
Link did not work:
Root Folder to files
ST80 File Link
I also hope this helps,
Aguaazul
