    Chinese Bias Volt Meters
    Rbertalotto
    Chinese Bias Volt Meters Empty Chinese Bias Volt Meters
    Post by Rbertalotto Mon Mar 15, 2021 11:30 am
    Chinese Volt Meters for Bias adjustment....Today I received my 0-1V analog meters for installation in a custom base for the VTA St-120. I connected them to see accuracy. In a word, fantastic. Great hysteresis and dampening. I bought both 0-1V and 0-3V version. Certainly the 0-1 has better accuracy and easier to see movement. I compared the reading to my VOM. Perfect!....$8.50 Shipped! How can they do this. I sourced Simpson meters made in USA...$113 each!!!
    https://www.ebay.com/itm/DC-0-1V-Round-Analog-Voltmeter-Analogue-Voltage-panel-meter-Dia-66-4mm-DH52/174353096301?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
    Chinese Bias Volt Meters P1040079-vi
    Tom Pickett and edman44 like this post
    Tom Pickett
    Tom Pickett
    Chinese Bias Volt Meters Empty Re: Chinese Bias Volt Meters
    Post by Tom Pickett Mon Mar 15, 2021 3:49 pm
    Rbertalotto wrote:Chinese Volt Meters for Bias adjustment....Today I received my 0-1V analog meters for installation in a custom base for the VTA St-120. I connected them to see accuracy. In a word, fantastic. Great hysteresis and dampening. I bought both 0-1V and 0-3V version. Certainly the 0-1 has better accuracy and easier to see movement. I compared the reading to my VOM. Perfect!....$8.50 Shipped! How can they do this. I sourced Simpson meters made in USA...$113 each!!!
    I just now got these gold plated 8 pin octal tube base socket plugs today and as I was hoping they are bakelite.
    The inside diameter is 1-1/8".
    Sadly I doubt very seriously that I'm gonna be able to find small enough analog meters to fit inside these octal plugs so I may have to go digital even if I don't want to.
    Chinese Bias Volt Meters 16114611
    Chinese Bias Volt Meters 16129011
    Rbertalotto
    Post by Rbertalotto Mon Mar 15, 2021 3:52 pm
    Tom, where did you get those sockets. I’d rather not remove the sockets in my amp. I could use these to make my meters “plug and play”
    Tom Pickett likes this post
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Mon Mar 15, 2021 4:00 pm
    Rbertalotto wrote:Tom, where did you get those sockets. I’d rather not remove the sockets in my amp. I could use these to make my meters “plug and play”
    Also Rbertalotto..... If you don't aready know ? Put an inline fuse to one side of both meters so if one of your tubes goes bad it will not be able to send a high voltage surge and burn out your meters.
    Here is the link to the octal socket plugs. https://www.tubedepot.com/products/8-pin-octal-tube-base-only-deep
    Rbertalotto
    Post by Rbertalotto Mon Mar 15, 2021 5:20 pm
    Thank you. I'll do the fuse thing. Great advise.
    Can I use one fuse on both grounds or does it need to go on the + side of the meter?
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Mon Mar 15, 2021 7:31 pm
    Rbertalotto wrote:Thank you. I'll do the fuse thing. Great advise.
    It needs to be on the + side of the meter as with all fuses. This is standard recommended practice is to place the fuse near the positive terminal of a battery or in a DC circuit, so the whole circuit will be dead if the fuse blows.
    Rbertalotto
    Post by Rbertalotto Mon Mar 15, 2021 8:00 pm
    But doesn't DC current flow from negative to positive...I thought all DC current flowed this way?
    "Current direction
    Electrons flow from negative to positive. In a direct current (DC) circuit, current flows in one direction only, and one pole is always negative and the other pole is always positive. In an alternating current (AC) circuit the two poles alternate between negative and positive and the direction of the current (electron flow) reverses periodically."
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Mon Mar 15, 2021 8:59 pm
    Rbertalotto wrote:But doesn't DC current flow from negative to positive...I thought all DC current flowed this way?
    "Current direction
    Yes.... that is true but if the meters metal casing is grounded to the negative lead inside of the meter and to the ground of the amp cassis then the fuse becomes useless.
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Mon Mar 15, 2021 9:38 pm
    When I used to have my own electronics repair shop back in the early 80's it was common to find when output tubes go bad and they are not fused properly they will start taking out other components including amperage and volt meters. I have also seen a few Dynaco ST 70's taking out other components when not fused properly when someone did not put back the proper rated fuse back in the fuse socket.
    Rbertalotto
    Post by Rbertalotto Mon Mar 15, 2021 10:06 pm
    "but if the meters metal casing is grounded to the negative lead "
    Ah, understood! Thank You
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Tue Mar 16, 2021 12:34 am
    I was looking at your V meters again and they look nice.... Question... is the outer casing metal or plastic ?
    Rbertalotto
    Post by Rbertalotto Tue Mar 16, 2021 4:58 am
    Plastic case
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Tue Mar 16, 2021 1:13 pm
    Rbertalotto wrote:Plastic case
    Still a nice meter Rbertalotto.... Let me know how those work out... Chinese Bias Volt Meters 1f600
      Current date/time is Tue May 07, 2024 2:40 am
