+2
DavidR
Tom Pickett
6 posters
    My Average Line Voltage Is 122.5 Volts
    Tom Pickett
    Tom Pickett
    My Average Line Voltage Is 122.5 Volts Empty My Average Line Voltage Is 122.5 Volts
    Post by Tom Pickett Sun Apr 04, 2021 12:19 am
    I have been measuring my line voltage everyday 3 times a day for a month and my average line voltage is 122.5 volts. So I will defiantly be building a bucking transformer circuit for my VTA ST 120 to save my tubes.
    10-E-C, jonny6336 and New2Tubez like this post
    My Average Line Voltage Is 122.5 Volts Empty Re: My Average Line Voltage Is 122.5 Volts
    Post by Guest Sun Apr 04, 2021 11:10 am
    I use a Hammond 167U5 which is rated for 15 amps. Complete overkill but it only cost a few dollars more than a lower rated model. I have it wired so it drops 2.5 or 5V depending on the supplied voltage that day. I use a switch to control the different voltages. It’s actually more like 2.8 and 5.6V.
    DavidR
    DavidR
    Post by DavidR Sun Apr 04, 2021 11:29 am
    Tom Pickett likes this post
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Sun Apr 04, 2021 11:44 am
    Earl wrote:I use a Hammond 167U5 which is rated for 15 amps. Complete overkill but it only cost a few dollars more than a lower rated model. I have it wired so it drops 2.5 or 5V depending on the supplied voltage that day. I use a switch to control the different voltages. It’s actually more like 2.8 and 5.6V.
    I was looking at this one at 6 amps Hammond 166Q6
    https://www.mouser.com/ProductDetail/Hammond-Manufacturing/166Q6?qs=zAx27f%252BWkoElcPca8RQ65g%3D%3D
    Some have suggested the Hammond 166N6 at 4 amps but that transformer may run a little to hot for my liking.
    https://www.mouser.com/ProductDetail/Hammond-Manufacturing/166N6?qs=dhCoiiGcT1IAXD2gHZeluA%3D%3D
    LeGrace
    LeGrace
    Post by LeGrace Sun Apr 04, 2021 5:09 pm
    I opted for Hammond 167U6 for my bucker.
    My Average Line Voltage Is 122.5 Volts Bucker-jpg
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Sun Apr 04, 2021 5:43 pm
    LeGrace wrote:I opted for Hammond 167U6 for my bucker.
    Went and looked at the specs for the Hammond 167U6 and it's perfect for this application.
    It’s nice and heavy and this transformer should hold it's own with any gear you use with it.
    Saved to my favorites.
    Link:
    https://www.digikey.com/en/products/detail/hammond-manufacturing/167U6/455329?utm_adgroup=Power%20Transformers&utm_source=google&utm_medium=cpc&utm_campaign=Shopping_Product_Transformers&utm_term=&utm_content=Power%20Transformers&gclid=CjwKCAjwx6WDBhBQEiwA_dP8rUqE13kSir0jVapKAyrGJ8RwoRm9W4wz-_3wUbZiDfIJZrQg3uqgNBoCY-8QAvD_BwE
    Spec Sheet pdf
    https://media.digikey.com/pdf/Data%20Sheets/Hammond%20PDFs/167_Series-Rev2018.pdf
    Rbertalotto
    Post by Rbertalotto Mon Apr 05, 2021 2:31 pm
    Why not just use a $50 5Amp variac?
    Bob Latino likes this post
    Tom Pickett
    Tom Pickett
    Post by Tom Pickett Mon Apr 05, 2021 11:51 pm
    Rbertalotto wrote:Why not just use a $50 5Amp variac?
    I would do that if I did not have some disabilities. I have an inner ear disease that on occasion causes extreme vertigo and sometimes I become very dizzy and clumsy. I need a fixed bucking transformer so I don't accidentally bump a knob or switch like a variac that would destroy my amp if the voltage was turned up to high. Plus I already have an old variac that i'm not using anymore for this reason. Sadly it's the product of getting older and having to adjust to certain realities.
    wildiowa
    Post by wildiowa Tue Apr 06, 2021 3:25 am
    Higher line voltage here sometimes up to 126 but normally 124 plus. Pre-Variac, two red plate disasters...post-Variac, zero. I prefer the Variac maybe duct tape the knob in place.
    Bob Latino, 10-E-C and Tom Pickett like this post
    New2Tubez
    Post by New2Tubez Thu Apr 08, 2021 11:16 am
    I asked Bob about these and he mentioned tube amps liking a sine wave and most of the affordable conditioners don't do this so I didn't proceed even though I had one in the house.
    Last edited by New2Tubez on Thu Apr 08, 2021 11:20 am; edited 1 time in total (Reason for editing : couldn't delete this. next post is more clear)
    New2Tubez
    Post by New2Tubez Thu Apr 08, 2021 11:18 am
    I asked Bob about these and he mentioned tube amps liking a sine wave. Most of the affordable power conditioners don't do this so I didn't proceed even though I had one in the house.
      Current date/time is Mon May 06, 2024 2:32 pm
