Since wall current is appx 120V and the 70 is 117V(?), is this a concern?
Also have a couple other pieces of 60s equipment which are below 120V. Don't think a variac would do.
Any advice and info on what to use, would be appreciated. Thanks.
raudio44 wrote:Thank you for the reply. I wasn't /am not sure using a variac would hold the desired input voltage steady. Now I am not a tech and just trying to understand what I need.
Going by your note, I will look closer at a Variac. In general, was looking to get some direction/ knowledge about transformers. Thanks again, it is appreciated.
New2Tubez likes this post
corndog71 wrote:I’ve used a variac but found a bucking transformer to be a more elegant solution. All you need is a 5 or 6 volt transformer rated for the current of the amp. I went a little higher and built several with 5, 10, and 20 Amp ratings just to be sure. They’re pretty simple to build. You just need to check your connections thoroughly.
Here’s the last one I built for my M125 monoblocks.
https://www.flickr.com/photos/79446895@N00/51819768697/
aguaazul wrote:There is a guy on Ebay with 2 offerings, one has a switch.
Without Switch
With Switch
Not sure what the switch does, either on / off or 3% / 7% is my guess.
Cheers,
Aguaazul
scrotuss wrote:2) I have never done this myself, but for those who frequently monitor their line voltage, what kind of swings do you get?
mijohn likes this post
