+7
LeGrace
rebellovw
aguaazul
scrotuss
Brap
raudio44
11 posters
    ST70 Line Voltage?
    raudio44
    ST70 Line Voltage? - Page 2 Empty Re: ST70 Line Voltage?
    Post by raudio44 Fri Apr 08, 2022 9:40 am
    Well I was just looking for advice regarding what to use to drop the line voltage into the ST-70. my intention is for equipment protection, not concerned about voltage regulation in a strict sense.
    so now a little confused. seems like either a Variac or a step down transformer (bucking) would work; just looking for a simple method. the size of a transformer, from what I have seen, would be more desirable than a larger Variac. I have space issues. I am open to either.
    cci1492
    cci1492
    Post by cci1492 Fri Apr 08, 2022 11:21 am
    I put together a bucker with a toggle switch to select -3 VAC or -6 VAC (about for each). My voltage some days is as high as 128VAC, never lower than 122 VAC.
    Mouser #:546-167U6 transformer
    sorry for the insanely large photos, don't know how to reduce their sizes
    ST70 Line Voltage? - Page 2 Img_7212
    ST70 Line Voltage? - Page 2 Img_7211
    ST70 Line Voltage? - Page 2 Img_7210
    Last edited by cci1492 on Fri Apr 08, 2022 11:39 am; edited 1 time in total (Reason for editing : added p/n for TA)
    raudio44 likes this post
    tubey1
    Post by tubey1 Fri Apr 08, 2022 11:27 am
    I'd just go with a bucking trans and forgot about it - I use my Variac on my test bench and it is big. Also if you bump or accidently move the knob on the variac is a concern. Just my 2 cents
    raudio44
    Post by raudio44 Fri Apr 08, 2022 11:47 am
    [quote="cci1492"]I put together a bucker with a toggle switch to select -3 VAC or -6 VAC (about for each). My voltage some days is as high as 128VAC, never lower than 122 VAC.
    Nice work!
    Last edited by raudio44 on Fri Apr 08, 2022 11:48 am; edited 1 time in total (Reason for editing : removed pictures in reply)
    ttocs
    ttocs
    Post by ttocs Fri Apr 08, 2022 11:48 am
    A few volts can make a big change of voltage internally. Here's a comparison of 115.1V vs 120.6V and what happens internally for my M-125 amps. The biggest change is 43V from only a 3.5V change of line voltage.
    ST70 Line Voltage? - Page 2 M-125-11
    raudio44
    Post by raudio44 Fri Apr 08, 2022 11:53 am
    tubey1 wrote:I'd just go with a bucking trans and forgot about it - I use my Variac on my test bench and it is big. Also if you bump or accidently move the knob on the variac is a concern. Just my 2 cents
    That's been my thought all along. Thanks for the input. Now to find one.
      Current date/time is Fri May 10, 2024 11:08 am
