Those small diodes only handle a continuous 1 amp load... When you say they will handle a 30 amp surge you have to keep in mind that's only 8.3ms (milliseconds) and then it's toast.
That's not completely correct. 1.0 amps is the AVERAGE current they can handle. If you look at the On Semiconductor data for the 1N40** series here:
https://www.mouser.com/datasheet/2/149/1N4007-888322.pdf
Or the Vishay data sheet for their UF54** series here:
https://www.vishay.com/docs/88756/uf5400.pdf
and scroll down to the figure 3 chart on either datasheet, you'll see that while the maximum of 30 or 150 amps (depending on which diode you are looking at) is sustainable for 1/2 of a 60Hz sine wave (which lasts 8.3 milliseconds), you'll see that after 100 cycles (830 milliseconds, almost one full second) both diodes are still rated to carry 10 times or more of their rated average current. So the diodes will NOT fail instantly - so as long as the average is within the device's limits.
None of this has anything to do with how the amp is fused. I'm only trying to point out what it takes to prevent diode failures from overvoltage/PRRV or overcurrent conditions.
If you want to use larger/higher rated devices that's fine, go ahead. Look at an amp with a 350-0-350 volt AC power trafo secondary feeding a full wave center tapped diode rectifier with a capacitor input filter setup configuration. That amp will have about 490 volts DC B+ voltage on one side of the diode; and on the other side of the diode you have an AC sine wave that varies from about +350 volts at the "top" of the AC wave to about -350 volts at the "bottom" of the AC wave. At the bottom of the AC wave therefore, you'll have -350 volts on one side of the diode and +490 volts on the opposite side. So the total voltage across the diode will be about 840 volts! For me, that's too close to the PRRV limit of the UF5408, so I use 2 in series and I'm now covered in case of a surge, a high AC line voltage, etc. For about $0.50 for a UF5408 diode it's cheap insurance.
The "yellow sheet" mod puts the heaviest voltage and switching loads on the diodes and in doing so makes life for the tube rectifier much easier. So use good diodes!
