One of the WZ68 copper caps I use in my M125s finally failed (after about a year). Symptom was blowing fuses. I opened up the unit just to check everything out to be sure.
I took the opportunity to do the yellow sheet mod with Fr207 diodes, and add some Mogami signal cable vs the twisted wire. Playing music again I decided to "fix" the copper cap.
One of the 1N4001 diodes in the unit did in fact fail. Since I have a basement full of diodes... I was able to dis-assemble the copper cap, replace the diodes, and put it all back together. The circuit is simple... 2x14N001 diodes on each leg, and NTC-100D-11 thermistor I was not able to cross reference and 2x18ohm 10W resistors feeding pin 8. NTC gives slow start, resistors give the drop. I put in the same FR207 diodes, for no reason other than insurance.
Now, when I put the copper cap back in service.... I will have three diodes on each leg of the rectifier, insurance, overkill, or no big deal?
PS I did order another copper cap too.
Bob C
Bob C
Last edited by Rec on Tue May 11, 2021 2:41 pm; edited 1 time in total (Reason for editing : name)
