I've just completed the rebuild of a pair of MKIII's. I installed the VTA octal driver board and the original quad cap was replaced with the SDS (Sheldon Stokes) cap board. I also replaced the original hook up wire, input jack, and speaker terminals. The amps power up nicely and hold bias. My readings from 122 vAC line voltage are:
VTA boards:
- B+: 463 vDC
- C14: 315 vDC
- C16: 398 vDC
- Red/Black bias: 57 vAC
- Bias diode out: 79 vDC
Rectifier amp1:
- Pin 2 and 8: 590 vDC
- Pin 4 and 6: 437 vAC
Rectifier amp2:
- Pin 2 and 8: 548 vDC
- Pin 4 and 6: 430 vAC
6550 amp1
- Pin 2 and 7: 6.85 vAC
- Pin 3 and 4: 589 vDC
- Pin 5 and 6: -59 vDC
6550 amp2
- Pin 3 and 4: 535 vDC
- Pin 5 and 6: -69 vDC
Anyone see any problems there? Should the amps be used with a variac to lower the line voltage? The rectifier tubes are old stock 5AR4's.
In system, the amps sound very good.
Thanks for any ideas or suggestions,
Ed
VTA boards:
- B+: 463 vDC
- C14: 315 vDC
- C16: 398 vDC
Rectifier amp1:
Rectifier amp2:
6550 amp1
6550 amp2
Ed
