    ST-70 - Can Not Set Bias
    Philagot
    ST-70 - Can Not Set Bias Empty ST-70 - Can Not Set Bias
    Post by Philagot Mon Jul 12, 2021 5:09 pm
    I have an ST-70 that has been working well for a few years. Last week it started making a buzzing noise so I checked the Bias, It would not go over .3V using any of the VTA's pots, so I figured its the rectifier tube. I changed the rectifier tube still staying around .3V with the pots at max. There is still what I believe to be a transformer/amp buzz.
    Any help would be appreciated.
    Mark
    ST-70 - Can Not Set Bias Empty Re: ST-70 - Can Not Set Bias
    Post by peterh Mon Jul 12, 2021 5:17 pm
    Philagot wrote:I have an ST-70 that has been working well for a few years. Last week it started making a buzzing noise so I checked the Bias, It would not go over .3V using any of the VTA's pots, so I figured its the rectifier tube. I changed the rectifier tube still staying around .3V with the pots at max. There is still what I believe to be a transformer/amp buzz.
    Mark
    You could have a leaking / bad can cap. Check DC voltages, if they are low you could suspect the can cap.
    michael.samra likes this post
    michael.samra
    ST-70 - Can Not Set Bias Empty To Peter and Philagot about your bias issues
    Post by michael.samra Sat Jul 24, 2021 10:01 pm
    I just looked at the OP again and realized it said your bias was .3v and not 3 volts. Yes, the twist loc cap will cause the drop in B+ and therefore you
    won't be able to bias it up to the 1.56v. You can also have a shorted EL34 or two that would load the B+. Check and see what your voltage is at pin 3 of each
    output tube. Now if the bias voltage was 3v and not .3vdc, then the selenium rect and the two 50uf axial lead caps need changing. I would change all those caps
    if they are original.
    Last edited by michael.samra on Sun Jul 25, 2021 1:41 am; edited 2 times in total (Reason for editing : I thought the bias was 3v and didn't see the decimal. I need reading glasses.)
    solderblob
    solderblob
    Post by solderblob Sat Jul 24, 2021 10:59 pm
    Did you try swapping output tubes?
    tuberadios69
    Post by tuberadios69 Sat Jul 24, 2021 11:11 pm
    I had the same issue a few years ago and it was the multi-section twist-lok capacitor. If yours still has the original cap in it (on top of chassis), I'd replace it immediately. the two 50uv@75V bias caps should be replaced, too. I'd use 100uv@100v.
      Current date/time is Sat Apr 27, 2024 11:21 am
