    Tight tube sockets
    docswanson
    Tight tube sockets Empty Tight tube sockets
    Post by docswanson Fri Sep 17, 2021 12:11 pm
    Hello all,
    In my recent ST-70 project with the VTA driver board, I find that the tube sockets on the driver board have incredibly tight pin holders.  When inserting 12AU7's, I am afraid I may damage the board, it takes so much pressure as I rock them in.  Is there any way to loosen the sockets, or maybe lubricate the pins to make tube rolling easier?
    mijohn
    Tight tube sockets Empty Re: Tight tube sockets
    Post by mijohn Sat Sep 18, 2021 1:46 am
    I suggest you remove the back cover and turn the amp on it's side. While supporting the driver board near the sockets with one hand, firmly push in the tube with the other hand. Deoxit might help too, you could try that first.
    Pablo
    Post by Pablo Sat Sep 18, 2021 9:02 am
    I cured a case of tight tube sockets on my VTA SP14 preamp using the method mijohn describes, but I made sure I was using a low value tube in case it was damaged by the process.
    Donspokane likes this post
    DavidR
    DavidR
    Post by DavidR Sat Sep 18, 2021 11:10 am
    Are you using NOS tubes or new production. I have found that the NOS tube pins are slightly larger in diameter. Some more than others. The new production pins are slightly smaller. Perhaps they are metric sized.
    docswanson
    Post by docswanson Sat Sep 18, 2021 1:47 pm
    Yes, I am using NOS tubes. I may have to support the back as mijohn suggests.
    DavidR likes this post
      Current date/time is Tue May 07, 2024 6:19 pm
