My St70 Filament is 6.7 on both sides instead of 6.3v. Should I be concerned and put a dropping resistor in series or just leave it?
ST-70 Filament voltage?
peterh- Posts : 1833
Re: ST-70 Filament voltage?
Is this with all tubes connected ?tubey1 wrote:My St70 Filament is 6.7 on both sides instead of 6.3v. Should I be concerned and put a dropping resistor in series or just leave it?
tubey1- Posts : 13
yes... with all tubes running,
I assume your mains voltage is a bit high. Any plans for reducing this ( with a buck transformer or similar) ?tubey1 wrote:yes... with all tubes running,
If you can find 0.15 ohm ( 1w) resistor that would reduce filament voltage 0.4Volt
( one resistor on each side )
tubey1- Posts : 13
Yes... mains are 122V here. I'd have to order up a couple resistors. Do you think it's ok now with 6.7v or is it necessary to bring it to 6.3V ? There must be alot of folks in the US ... these old transformers were designed for less than 122v.. the voltages in the US have risen a couple times over the years.
- Post n°6
It's not necessary but it will make life better for the tubes. ( too high filament voltage shortenstubey1 wrote:Yes... mains are 122V here. I'd have to order up a couple resistors. Do you think it's ok now with 6.7v or is it necessary to bring it to 6.3V ? There must be alot of folks in the US ... these old transformers were designed for less than 122v.. the voltages in the US have risen a couple times over the years.
their life, BUT most likely your tubes will be replaced before that by normal aging)
Roy Mottram- Admin
- Post n°7
bucking or step down or variac recommended to reduce your voltage to the amp from 122 to 117v
Brap- Posts : 231
- Post n°8
Purchased a varic last year per Bob's recommendation. Good $65 investment for my ST-70. Where I live, I had ranges from 116 to 126. Adjust it to 119 now. Also nice to have for bench work. It's a 5 amp model.
