    SP 14 Uneven Gain
    manookjs
    SP 14 Uneven Gain Empty SP 14 Uneven Gain
    Post by manookjs Wed Feb 16, 2022 2:09 pm
    I build this SP 14 about 5 years ago and it has been a great performer.
    Recently I've had to adjust the right gain all the way up and reduce the left gain to about 75%.
    I don't know if my tubes are getting weak or if there is another problem.
    May I request your input as to what you think may be the problem?
    The original tubes were used when I got them.
    John
    Rbertalotto
    SP 14 Uneven Gain Empty Re: SP 14 Uneven Gain
    Post by Rbertalotto Wed Feb 16, 2022 2:55 pm
    Swap the tubes Left to Right and visa-versa....See what happens. Is there any noise in the volume controls. If yes, spray contact cleaner might fix the problem.
    manookjs
    Post by manookjs Wed Feb 16, 2022 3:02 pm
    I'll try to swap them out and see if the situation reverses itself.
    The volume controls are quiet.
    manookjs
    Post by manookjs Sat Feb 19, 2022 10:27 am
    I switched the tubes with no change in volume.
    I then re flowed the solder on the right and left gain.  It worked!!!
    Roy Mottram, Dale Stevens and MechEngVic like this post
    Post by Roy Mottram Thu Mar 03, 2022 2:30 pm
    poor solder connections are the source of 90% of all problems we find with customer build tube gear.
    MechEngVic likes this post
      Current date/time is Wed May 08, 2024 6:33 am
