    Splicing and soldering
    Jlskey
    Splicing and soldering  Empty Splicing and soldering
    Post by Jlskey Fri Apr 29, 2022 4:21 pm
    So while performing surgery on my st 120 a few weeks back I noticed that I just wasn’t happy with the solder connections on quad cap lugs. Issue is, a lot of the wires have already been cut fairly short so Unsoldering them to get a better mechanical connection may be a bit tough.
    So I was thinking: why not just get some wire and splice it to extend the wire and then get a good mechanical connection to the lugs and solder?
    Any thoughts on this? Was definitely going to use the 20 gauge solid core where appropriate (I.e the scm)Wasn’t sure what type of wire was used coming off the power transformers however. Figured I’d use a combination of heat shrink tubing as well as electrical tape to wrap. Any thoughts are appreciated!
    rebellovw
    Splicing and soldering  Empty Re: Splicing and soldering
    Post by rebellovw Fri Apr 29, 2022 6:52 pm
    I did exactly as you are talking about.  My transformer wires were all too short after burns and resoldering etc.  So completely rebuilt my amp (see my M125 thread) using:
    Tefzel 18AWG stranded. 600V rating and HTFE - tinned copper.
    Stuff above is awesome.
    You can also see my thread on AK:
    https://audiokarma.org/forums/index.php?threads/yellow-paper-mod-vta-m125s-did-it-help-my-situation.985784/
    I also bought some 18AWG stranded tinned 300V in many colors: JMS822-01G - Jameco along with their 20AWG solid tinned copper - but I mostly used the Tefzel.
    Jlskey likes this post
    Jlskey
    Post by Jlskey Fri Apr 29, 2022 10:21 pm
    rebellovw wrote:I did exactly as you are talking about.  My transformer wires were all too short after burns and resoldering etc.  So completely rebuilt my amp (see my M125 thread) using:
    Thanks for the suggestions!
    Post by corndog71 Fri Apr 29, 2022 11:15 pm
    When I built my custom version of the M125s I had to get creative with some of the transformer wires that were cut for the original chassis.  I use Kimber TCSS 19awg Teflon insulated wire to extend the blue and green wires as well as the red/black wire.
    Splicing and soldering  29707077827_ed47f8818f_z
    Jlskey
    Post by Jlskey Sun May 01, 2022 10:39 am
    Meant to ask earlier: I noticed that some of the wires inside the amp are threaded and some are solid core. Do I need to splice and Solder threaded to only threaded and solid core to only solid core?
    rebellovw
    Post by rebellovw Sun May 01, 2022 1:51 pm
    The only ones I spliced (if needed) were the transformer leads or the choke leads - everything else I replaced completely.  Those leads were all stranded.
    Thanks.
      Current date/time is Sun Apr 28, 2024 11:58 am
