by rebellovw Wed Jul 13, 2022 8:13 pm
New2Tubez wrote:" I'd avoid the Weber WS1 like the plague - the WZ68 I've had good luck with and is the only one I'd use."
Can you explain why? I use the WS1-t (thermistor) version in my ST120 and it's been fine for 2 years and I didn't blow 5AR4's prior to that.
I use a variac set to about 116-117vac and the auto bias board which has delay by design. I switched to the SS after installation of the AB.
Also, at this point, I think the plague is UN-avoidable
I posted a thread on this here. Right after the rebuild of one of my M125s - I ordered two new WS1/Ts. My tech went over the amp and replaced a couple bad resistors and a bloated cap - the amp was completely finished and working perfectly.
We took out the WZ68 and put in the WS1/T - powered up - terrible sound and bam - fuse blown. We tried the other WS1/T - same issue. We put back in the WZ68 - and worked just fine - we also put in a GZ37 Mullard - worked fine.
I couldn't get the WS1 to work at all - I sent back to Weber - they said nothing wrong with them - yet they couldn't explain why the WZ68 had no issues. They were just as confused as I was.
The WS1 just turned on - made a terrible contracting sound from inside of it and fuse blown. Like instant over voltage. I'm only running two output tubes - perhaps that is why -I just don't know - I never had issues with Rectifiers in all my years with these amps (2011?2012?)
