I was with my tech today who finished repairing the issues with my M125 amp - I also had him install the Rubli delay board.
Amp was working just fine with the WZ68 and two output tubes - I told him I'd be running with the WS1 - so we plugged that in - turned the amp on and immediately - whap - fuse blown.
He then replaced the fuse and controlled the incoming voltage to prevent a blown fuse and each time - whap (it would have blown a fuse)- we even tried the other WS1/T - same issue. Went back to the WZ68 and all is fine.
I'm home with the amp - and I've tried the old Mullard GZ37 - works just fine - and I'm using my bucking transformer - so my voltage is around 116v.
I'm only running two output tubes and the bias at .500 v. The delay of close to 30 seconds - hadn't even kicked in - it went straight to blown fuse. I also have the yellow sheet mod.
I've sent an email to Weber - I'm just surprised the WZ68 is absolutely fine - and this thing just doesn't work - I assume is it incorrectly built.
