    Coupling caps for 6SN7 driver board question
    Telescope12
    Coupling caps for 6SN7 driver board question Empty Coupling caps for 6SN7 driver board question
    Post by Telescope12 Mon Sep 12, 2022 10:37 am
    I'm upgrading my board to the 6SN7 version and I would like to pre order a few parts. I've downloaded a schematic and the coupling caps are listed as 0.33uf. However, the picture on the website clearly shows a 0.22uf cap installed on the board.
    Which uf value coupling cap would I need to preorder?
    Is there an updated schematic I can use so I can order the correct parts?
    Charles
    Coupling caps for 6SN7 driver board question Empty Re: Coupling caps for 6SN7 driver board question
    Post by Bob Latino Mon Sep 12, 2022 3:43 pm
    Telescope12 wrote:I'm upgrading my board to the 6SN7 version and I would like to pre order a few parts. I've downloaded a schematic and the coupling caps are listed as 0.33uf. However, the picture on the website clearly shows a 0.22uf cap installed on the board.
    Charles
    Charles,
    You can use either .22 or .33 uF caps of at least 400 voltage rating. 630 volt rated .22 or .33 uF caps will also work OK.
      Current date/time is Sat Apr 27, 2024 2:19 pm
