    ST 70 power transformer
    zapped1
    ST 70 power transformer Empty ST 70 power transformer
    Post by zapped1 Fri Nov 11, 2022 5:00 pm
    Happy Friday all, this is my first post here on the forum,( I'm also a tube equipment newbie). I have been working on a ST70 and I'm going thru the wiring looking for cold solder joints or???
    I'm looking at the power transformer and the colors of the wires have faded to the point that red looks white, brown looks white ect. Is there any way to determine these colors? Could I remove the trans ,open the case to see if there's any color in there? Obviously the amp worked at some point in it's life; although I don't know it's history. Any advise is appreciated Thanks Gary
    New2Tubez
    ST 70 power transformer Empty Re: ST 70 power transformer
    Post by New2Tubez Fri Nov 11, 2022 6:15 pm
    If it's original (not modified/messed with) you could download the manual/wiring diagram. I think it's in the stickies area of the basket on this forum. Look at what the trans. wires connect to and maybe label the wires.
    I'm just guessing. I built the VTA ST120 kit from new.
    itrfguy likes this post
    zapped1
    Post by zapped1 Fri Nov 11, 2022 8:42 pm
    Thanks for that, I already have the build instructs and manuals
    Post by Roy Mottram Sat Nov 12, 2022 7:10 pm
    same advice, look at where the leads are connected and then you'll know what's what
      Current date/time is Sat Apr 27, 2024 2:33 am
