    weird observation with my A470 output transformers
    Sichum
    weird observation with my A470 output transformers Empty weird observation with my A470 output transformers
    Post by Sichum Mon Jan 02, 2023 4:37 pm
    Greeting,
    While checking my st-70 for possible shortage, I noticed there is continuity between the chassis and every speaker posts. Thinking those speaker terminals were shortage somehow, I removed all wires and redo them all and tested without the output transformer wires connected. No continuity. I thought that was great and went ahead solder those wires back into place. I tested them again after soldered them and the continuity was there again. Is that behavior expected? if not, what's going on there? Any help is much appreciated. Thank you
    weird observation with my A470 output transformers Empty Re: weird observation with my A470 output transformers
    Post by peterh Mon Jan 02, 2023 5:07 pm
    Sichum wrote:Greeting,
    The common output is grounded in the amp, this serves as reference as the 16ohm
    is used for NFB
    Have a look in the schematics !
    Buck_R0gers and Sichum like this post
    Sichum
    Post by Sichum Thu Jan 05, 2023 11:31 am
    is used for NFB
    much appreciated for your time. I read more about the NFB and starting to understand a bit more.
      Current date/time is Tue May 07, 2024 2:19 pm
