by jwb474 Wed Apr 26, 2023 8:21 pm
No, The Metric screws I referenced are ISO 724 - Metric Threads like M3, M4 etc.
UNF, Unified National Fine Threads, is a more specialized machine screw spec to ANSI B1.1 like 4-48, 6-40 etc.
UNC, Unified Coarse Threads, is the standard machine screw mostly used spec to ANSI B1.1 like 4-40-, 6-32 etc
SAE, Society of Automotive Engineers, has the same pitch as UNC.
The only other way that I can think of to fix your issue, especially without any disassembly is to a little southern engineering and get the keyway replacement and cut off the center keyway and use them as spacers.
Note: you may need to trim the edges for screw head clearance.
https://www.tubedepot.com/products/octal-tube-keyway-replacementLast edited by jwb474 on Wed Apr 26, 2023 8:23 pm; edited 1 time in total (Reason for editing : add note)
