The one that works is playing music but occasionally blows fuses. I am running KT88 tubes. The one that is down has no voltage on the bias. All the tubes are heating up but no sound. I switched one tube at a time from the good amp and the dead amp lit the tubes but still no sound. I live in Leominster Ma. Is there anyone near me that would be willing to work on them? I can do some testing if anyone has a recommendation
I have a pair of Dynaco original Mark IV's. One is dead. The other is playing but.....
ng8264723- Posts : 1
Big Harry- Posts : 51
If your amps have not been recapped, all of the tubes and resistors have been tested along with replacing the selenium rectifier in the bias circuit, there can be a bunch of problems in both amps that will need to be addressed. There is also the possibility that the power transformer or output transformer has failed. If your good amp is blowing fuses, you have a problem with that one also which will require a major service to make it reliable. I would be happy to service your amps, but I'm in Kingman, Arizona which would require shipping your amps to me. If you're interested, send me a PM.
WLT- Posts : 186
Another option to think about. I restore Dynaco vintage amps to original specs and layout. I am in Rochester NY which is not close but is derivable. I just checked and it is almost a 6 hour drive. If you are interested I could give you some references and we could have phone call to discuss options and associated costs. For sure we can have a phone call to talk you thru some testing you perform. It would verify if you have a major failure of one of the transformers. Send me a PM if interested. A recent photo of my MK IVs with new caps and resisters.
» Pair of Dynaco Mark VIs .... Worth a try?
» Just purchased a pair of Dynaco Mark 6 120 watt monoblocks
» Poor man's solid state replacement rectifier for Dynaco ST-70, Mark II, Mark III or Mark IV
» Run your Dynaco ST-70, Mark II, Mark III or Mark IV in TRIODE MODE - photo
» Dynakit Mark 3 cage and Dynaco Mark 2 chassis and bottom cover wanted
