SDS LABS Capacitor Board Dynaco PAS 3
stewdan- Posts : 231
FMZIP --- These are the links from Triodelectronics in the Chicago Area for a previous version of the SDS Cap Bd for the PAS, the hook up should be similar:
https://sep.turbifycdn.com/ty/cdn/triodeel/NEWPASCapboard2ManualPRINTONLY1through7.pdf
https://sep.turbifycdn.com/ty/cdn/triodeel/PASSCHEMATICNEWPURPLE.pdf
J1 and J2 are from the transformer for the filaments. But J1, J3 and J5 are all connected together, and J2, J4, and J6 are also all connected together. So the blue transformer wires and the lamp wires and the rectifier filament wires can use any combination of the groups of pads.
Hope this helps
Stew
Hope this helps
Stew
fmzip- Posts : 18
stewdan wrote:FMZIP --- These are the links from Triodelectronics in the Chicago Area for a previous version of the SDS Cap Bd for the PAS, the hook up should be similar:
Hope this helps
Stew
Thank you!
FMZIP ---- Did the links that I sent you help?
Stew
Stew
fmzip- Posts : 18
stewdan wrote:FMZIP ---- Did the links that I sent you help?
Stew
Yes! Thanks so much
