    Adding auxillary filament transformer?
    arficus
    Adding auxillary filament transformer? Empty Adding auxillary filament transformer?
    Post by arficus Mon Aug 28, 2023 5:56 pm
    I have 3 ST70s with octal VTA70 boards (yes, I'm a fan). I've been running them for years with stock power transformers. They run hot, but knock-on-wood, so far no failures. But I'm progressively growing more nervous. I could seek out replacement transformer, but am considering adding a separate filament transformer, such as Hammond 167T6 (6.3V, 12A). I might be able to fit it on chassis between power transformer and board. It would not have much clearance between itself and power transformer for cooling, but I'm guessing this would still be much preferable situation than continued over burdening of the PA060. My electronics knowledge doesn't extend much beyond following directions and soldering, so I ask: Is there any reason this approach is less desirable than replacing entire transformer?
    j.click
    Adding auxillary filament transformer? Empty Re: Adding auxillary filament transformer?
    Post by j.click Mon Aug 28, 2023 6:28 pm
    A friend gave me an AC whisper fan from an old computer stack that I set up behind my ST70 to keep air flowing over the PT and LOTs. It makes a noticeable difference in keeping things cool, is not obtrusive and much easier than other alternatives.
    arficus
    Post by arficus Tue Aug 29, 2023 2:17 am
    j.click wrote:A friend gave me an AC whisper fan from an old computer stack that I set up behind my ST70 to keep air flowing over the PT and LOTs. It makes a noticeable difference in keeping things cool, is not obtrusive and much easier than other alternatives.
    thanks for the reply, but the problem isn't merely the heat, it's the fact that using 3x 6SN7 in the driver stage causes total filament draw to go beyond PA060 spec.
    New2Tubez
    Post by New2Tubez Tue Aug 29, 2023 10:10 am
    Expensive option but if your existing ones are good you could sell them.
    http://www.tubes4hifi.com/AMP-PARTS.htm
    PS, no personal experience other than owning a VTA ST-120
    Dave_in_Va likes this post
      Current date/time is Thu May 02, 2024 5:44 pm
