    Bias PAnel meter install
    Brap
    Brap
    Bias PAnel meter install Empty Bias PAnel meter install
    Post by Brap Fri Nov 17, 2023 1:31 pm
    Bought the kit and did the install. GREAT addition to the VTA and gives the unit a classy upgraded look compared to staring at the Dynaco preamp sockets. Will installl panel mount test points to fine tune bias with a DMM but these look great and will give indications if something goes wonky. I got scraps of 35 grade darkness window tint from a local shop to go over the lexan. (in Dan's instructions too) Can't see the the readouts when the unit is off and provide a nice subtle blue hue of bias voltage when powered. Dan is working on version 0.2 of the kit with tint material or darker lexan. Will try and post a pic.
    Highly recommend.
    erniegiro likes this post
    teftamaqua
    Bias PAnel meter install Empty Re: Bias PAnel meter install
    Post by teftamaqua Fri Dec 01, 2023 6:33 am
    can you be a little specific about the name of the kit and where you bought it from
    Thank you….. Tim
    Brap
    Brap
    Post by Brap Fri Dec 01, 2023 9:40 am
    Look on the tubeforhifi site and you will find it when you searh around. Click on Dynaco ST70 parts and scroll down
      Current date/time is Thu May 02, 2024 3:26 am
