    AC Voltage On Chassis
    rudes
    AC Voltage On Chassis Empty AC Voltage On Chassis
    Post by rudes Fri Dec 29, 2023 12:00 pm
    Is it normal to read AC voltage between the chassis and earth ground on an st-70? I know that a 3 prong power cord can be added, but Dynaco produced thousands of units with the two prong.
    Dale Stevens
    AC Voltage On Chassis Empty Re: AC Voltage On Chassis
    Post by Dale Stevens Fri Dec 29, 2023 6:46 pm
    Rudes, what's your preamp? Could be coming from there. Some eq has a r/c network across the AC input. Over time the cap will leak to grd. Dale
    rudes
    Post by rudes Sat Dec 30, 2023 10:15 am
    This is with no input on the amp. This seems normal if using a two prong power cord. I also tested my Pas pre-amp and also get a voltage reading from the metal case to earth ground.
      Current date/time is Thu May 16, 2024 10:50 pm
